122-141
142-161
162-181
182-201
202-221
222-241
242-261
262-264
when I saved the file, Moi has crashed.
The "save to"-option works fine in this case.
I attach the moi-report here. Hope it's ok.
Best regards
Jörg
moi_report1.zip
Hi Jörg, thanks for sending the crash report. Does the crash happen when you are trying to save a particular file that you have loaded?
If so is it possible for you to send me the file at
moi@moi3d.com so I can try to reproduce the crash?
The crash report indicates the crash is happening in nvwgf2umx.dll which is part of the NVidia display driver, so it might be some problem with the video driver.
I might be able to figure out more though if I can repeat the crash over here.
I have send the 3dm-file to you. Hope it helps.
Jörg
Hi Jörg, I do not seem to have received the file. If it is pretty large you may need to use something like Dropbox and send a link to it rather than as a direct e-mail file attachment.
Thanks, - Michael
OOps! The file has a size of 1mb :)
I send it as attachment directly here. It's not somethink special.
Best regards
Jörg
SphereRacer1.zip
Hi Jörg, thanks for posting the file. I can't repeat the crash over here though, does it happen for you if you just open that file and then use Save?
Since your crash dump has the crash happening inside your video driver maybe there is a problem there. A few things you could try might be to update your video drive to the latest version and there are also a couple of moi.ini settings you could set that may help:
[View]
DisplayThreadLimit=1
That will disable the use of multiple cpu cores for the drawing engine, some video drivers may behave better with that.
And also:
[View]
StaticBufferMaxVRAMToUseMB=0
That will disable caching of display meshes on video card memory.
Does any of that make any improvement?
another bug is, when I hide the points on a curve, the curve will deleted.
I bring back with Control+Z and hide again the points. The curve is remains in the scene.
Try with a new freeform-curve and activate the points and then hide the points.
In my case the curve will deleted.
Best regards
Jörg
Hi Jörg, there isn't currently any way set up in MoI to hide individual points. If you have the curve selected at the time you do the hide, the curve will be hidden though but not deleted. You should be able to use Hide again to make it visible.
Ctrl+Z undo also works to undo the last change in visibility or selection.
thank you for this information. Is it a new feature? I never see this before.
Jörg
Message 9100.191 was deleted
Not a big deal, but:
Unless I am mistaken? I've noticed this morning that the f.lux program, which warms up Windows programs screen colors, during darker parts of the day,
SEEMS to be causing the Area Zoom Pan Reset panel at the bottom center of the MoIBeta4 screen to remain lighter than the f.lux colored MoI screen,
whenever the mouse pointer is in the gridlines area of the screen. This is not happening in MoI3.
(Hovering over the panel, the colors seem to match.)
So it seems like, for that area, the shade used by MoI does not reflect the f.lux modification?
Hi Jörg,
No, that's the same as it has always been.
For the crash is that something you can repeat over there using that file you posted?
If it was just a one time random crash you might try updating your video driver since the crash report showed the crash was happening in video driver code.
Hi Brian, re: f.lux - there is a difference from how MoI v3 and v4 handles that bottom viewport toolbar, in v4 it is a separate window layered on top since that was easier to do cross platform. So I guess that is affecting f.lux.
Uninstalled f.lux, and highlight problem went away. Snagit no longer suffers brownout either.
Re-installed updated f.lux, and no more problems.:-)
After a reboot, my MoI4 hotkey for Light node editor reverted to its prior value, so I must have the MoI3 version of hotkeys reloading?
I updated the Ctrl+Alt+N hotkey in MoI3, for Light node editor scheme, and all seems to be well now...
Hi Brian, by default MoI v3 and v4 both use the same moi.ini file where your shortcut keys are stored. So they will have the same shortcuts between them.
If you want though it is possible to make each of them use a separate moi.ini file and so have separate settings. To do that you can either pass the path to a moi.ini file as a command line parameter to moi.exe, or you can move the moi.ini file into the same directory as moi.exe and it will find it there but if you do the second one you would need to run moi.exe with elevated privileges ("Run as Administrator") because at the default privilege level Windows will prevent programs from modifying files in the "Program files" directory.
Thank you Michael.
My home computer (seems) to have voluntarily switched to using (non-appdata) MoI3 files of type .ini and nodeeditor, for MoI4beta,
or else it has been that way for 9 months or so until I recently updated nodeeditor in appdata...
Changing one shortcut key in MoI 4 did not update the MoI3 .ini, (??)
I changed the Ctrl+Alt+N for Light Scheme nodeeditor in MoI3, and now the hot key works in MoI4.
Last night I updated nodeeditor in C:\Program Files (x86)\MoI 3.0, and now nodeeditor again works in MoI4beta.
I do not recall if MoI3 can use the appdata folder for customui and nodeeditor...
So I am still confused...
I'll puzzle on it some more.
I really like the appdata method.
p.s. Everything seems to be working properly with the office computer.
Hi Brian, well one other complication is that settings are only saved to moi.ini when MoI shuts down.
So if you have MoI v3 and MoI v4 open simultaneously and make different changes in each one, they will have differences at that moment but the last one that you close will win out and have its settings in the moi.ini file.
Does that explain what you are seeing?
Thank you Michael.
That makes sense.
Anyway, I'm using MoI4beta 99% of the time so I'll keep the MoI3 .ini the same as MoI4beta's.
Yes, your explanation is correct.
With MoI4beta closed, I opened MoI3, and changed the CTRL+Alt+N shortcut key by adding ZONK before the final semicolon.
Closed MoI3. Opened MoI4beta. The shortcut key alerted finding "ZONK,' and did not load nodeeditor.
Removed ZONK, closed and reopened MoI4beta, and the hotkey worked to load nodeeditor Light scheme.
The Light scheme is more printer toner friendly...
Hi All
Have not been around for a while, just noticed the subd to Nurbs feature, I'm impressed.
Did a great job with my test model. the subd came from DazStudio, quit a complicated model.
Cheers, stephen
Hi stephen, that's great thanks for testing the SubD to NURBS conversion. There are also some tune-ups coming for that in the next beta release.
122-141
142-161
162-181
182-201
202-221
222-241
242-261
262-264
