Full Version: V4 beta Oct-17-2018 available now - SubD to NURBS conversion
Show messages:  1-11  …  72-91  92-111  112-131  132-151  152-171  172-191  192-211  …  252-264
9 Nov 2018   [#132] In reply to [#130]
Hi Christopher, you'd get that kind of error if the Nudge script is not installed. For v3 you must have installed it at some point by copying it into v3's commands folder. You'd need to do the same for v4 to get it to work.
For v4 you can also install commands into a commands sub-folder inside MoI's user data folder, you can find your user data location by using Options > General > Edit .ini file button, a dialog will pop up and tell you where your moi.ini file is located at which will be in your user data folder.
Copy the Nudge.js file from your v3 commands folder into the user data commands folder and v4 will look for it there and you won't have to keep copying it into new versions anymore.
9 Nov 2018   [#133] In reply to [#129]
Hi Michael.
I quite like the way MoI V3 handles it as you can look through the list of files, select the name you want and then choose the type of file extension you want to save it as. It allows slow/lazy/forgetful typers like me to have indentical file names with multiple extensions with near zero effort.
Martin.
9 Nov 2018   [#134] In reply to [#132]
Michael, thanks so much for reminding me that I installed a script for this. (Sorry I forgot.) I copied it into the Application Support subfolder as you suggested and I have my nudge keys again. Yay!
You might want to change the code that looks for scripts to have it output something like, "Script ____ can't be found. Install scripts in Application Support." :-)
Christopher
10 Nov 2018   [#135] In reply to [#134]
Hi Christopherm I'm glad you've got it working now. Yes, I have it on my todo list to make a warning message like that. Currently if a script file can't be found it tries to execute that text directly as script code which makes the kind of error message you were seeing.
17 Nov 2018   [#136]
I have a quick question about v4, I'd like to test it but I'm only using the trial for v3. I see a lot of meshes that have nice quads, if I model something from scratch in Moi does that mean it can export all quad meshes? Or is this kind of export only possible when a polygon mesh is imported in and converted? Sorry, it's a bit of an odd question I guess.
17 Nov 2018   [#137] In reply to [#136]
Hi Foxfire - sorry no MoI does not have any function for exporting all quad meshes. MoI has an exporter that makes N-gon meshes but that's not the same thing as "all quads".
You would generally need to open your exported mesh in a polygon modeling program and use retopology tools there to end up with all quads.
But why are you trying to generate all quads from your MoI model? If you want to render your model it doesn't need to be all quads to do that, you only need all quads if you wanted to apply sub-d smoothing to the mesh but that would be kind of unusual to do to an object created with CAD modeling.
17 Nov 2018   [#138] In reply to [#137]
The reason I wanted all quads was to make the mesh work better with Blenders bevel modifier. For some surfaces the Ngon export works fine but curved surfaces tend to be hit or miss, I can clean the mesh up to have it work better but having all quads would be a nice workflow improvement. I know I can bevel in Moi but the flexibility having the bevels as a modifier in Blender is very useful and I find that the edge selection in Moi to be a little tedious (when beveling the whole object isn't wanted) where in Blender it can be almost automatic. This way I could export a triangulated mesh out of Moi as well and use the beveled version from Blender as a high res for baking, at least that's what I was thinking for my workflow.
Would it be possible to implement an all quad export for Moi? It would be a great time saver and the models would be more flexible with other software outside of CAD.
17 Nov 2018   [#139] In reply to [#138]
Hi Foxfire, yes typically in CAD modeling the beveling is done on the CAD model itself and so the polygons that you export are all in the end shape already.
In the future I would like to work on an all quads export for MoI but it will likely be a quite difficult task and take a considerable amount of effort to develop. It needs a much different approach than the current mesh export.
Currently the way you would get all quads would be using retopo tools.
18 Nov 2018   [#140] In reply to [#138]
I can heartily recommend ZBrush ZRemesher or 3D-Coat Autopo for automatic quad-retopology of meshes exported from MoI:
https://www.metinseven.nl/blog/Ag4W/3d-coat-vs-zbrush-auto-retopology-comparison
19 Nov 2018   [#141]
Tried it out with the corvette tutorial model from cgmasters. Imported both the underlying clean reference surfaces as well as the detailed parts to review at which point it makes sense to convert to nurb. Both come in beautifully!
https://cgmasters.net/training-courses/master-car-creation-in-blender/
It is a little on the heavy side but this should be huge for my team- We have been increasingly using SubD techniques for concept modeling. This will be extremely useful for downstream communication with Engineering teams- even though the surfaces are heavy it is still something that a Mech Engg team member can open and evaluate component clearances general design intent etc:
Screenshot 2018-11-18 22.21.23.png  Screenshot 2018-11-18 22.33.12.png  Screenshot 2018-11-18 22.33.21.png  Screenshot 2018-11-18 22.34.04.png  Screenshot 2018-11-18 22.34.28.png  Screenshot 2018-11-18 22.36.54.png  Screenshot 2018-11-19 11.01.52.png  Screenshot 2018-11-19 11.01.59.png
19 Nov 2018   [#142] In reply to [#141]
Hi parel,
It's looking good! One thing to check - make sure you're exporting the roughest base control cage. You generally don't want to export polygons that have already been subdivided some already because that will make things a lot heavier.
19 Nov 2018   [#143] In reply to [#142]
Does this point count look appropriate for the control cage imported?
19 Nov 2018   [#144] In reply to [#143]
Hi parel yeah I guess so, each polygon in the original control cage that is at an extraordinary vertex will end up as a degree 6 Bezier patch meaning it has a grid of 7x7 control points, these are then combined with neighbors.
It could be possible to have an option to do a different style of patch combining where only the patches right around an extraordinary vertex get degree 6 and other areas get degree 3 patches with 4x4 control points. It would be fewer surface control points but also split up into more surfaces with smaller ones around extraordinary vertices.
It's kind of good to have a little lighter control cage, that one is kind of on the dense side.
However, despite the high control point count you should see very good shape quality with the surfaces all matching up very well.
Is it possible for you to send me the model at moi@moi3d.com so I can do a couple tests with it?
Thanks, - Michael
20 Nov 2018   [#145]
HI Michael,
Putting together a file for visual 3d pdf presentation - the file is 560meg - 2600 parts.
Moiv3 File takes 1.34 minutes to open
Moiv4 File takes 5.06 minutes to open
Rhino5 takes 0.50 minutes to open
I can organise for a shared link to file to run a load test - what do you think causes the wide variation in file handling time.
thanks
Alex.
20 Nov 2018   [#146] In reply to [#145]
Hi Alex, I have not yet come across any files that load slower in MoI v4 than in v3 so I don't really have any idea why that would be. Yes if you could please send me a shared link to it at moi@moi3d.com I can do some tests on it to see what is going on.
Also what are your system specs, do you have plenty of system RAM?
20 Nov 2018   [#147]
Just playing around with some boolean union cubes, save to .obj, and perform SubD.
Different results are obtained with SubD upon the .obj files, depending upon the original location with respect to the origin,
of the original 5 cube objects .3dm.
(Out of upload room, will clear space and post .obj later.
20 Nov 2018   [#148] In reply to [#145]
Hi Alex, re: large file loading - thanks for sending the file. Over here I get:
MoI V4 beta Oct-17 : 15 seconds
MoI v3: 70 seconds
Rhino v5: 27 seconds to load + 43 seconds "Creating meshes..." delay on first view navigation.
Additionally over here the V4 behavior is better all around than both MoI v3 and Rhino v5. On Both MoI v3 and Rhino v5 the main window is just frozen during the load while in MoI v4 the window doesn't freeze and there is a progress bar and cancel button.
My machine is fairly old, Intel Core i5-2500K Quad core CPU, 16 GB RAM, with an old style spinning disk.
I'd guess that your machine is probably a laptop? My theory is that with MoI v4 making heavy use of all CPU cores your machine doesn't like that sudden spike in energy use and it throttles the processor speed way down.
You can probably avoid this by making sure it is plugged in rather than running on battery power and then go to "Power Options" in the Windows Control Panel and make sure that the "High performance" power use plan is the one that is active. It's probably currently set to a plan that sacrifices performance for less battery use.
Does that make any difference?
Also I will put in a setting for the next v4 beta so you can turn off the multi-core processing for file loading.
21 Nov 2018   [#149] In reply to [#139]
Yah, I'll stick to my retopo tools for now but hopefully think about adding an all quad exporter! It would probably broaden Moi's use and appeal.
22 Nov 2018   [#150]
Did a speed check on my desktop workstation and same time as yours with my laptop I always have it plugged in and with best perfomance setting. Will look into other settings to see if can improve load times.
thanks again for your time.
regards
Alex.
22 Nov 2018   [#151] In reply to [#150]
Hi Alex, maybe check the advanced properties of the "High performance" power plan. Maybe it still has some CPU throttling set on it. If not I guess it is just getting too hot with all CPU cores running and throttling anyway. I'll make a setting in the next v4 beta where you can limit the number of CPU cores used for file loading maybe using just 2 or 3 cores on that particular machine will work better if it just can't thermally handle all at once.
