Full Version: V4 beta Oct-17-2018 available now - SubD to NURBS conversion
Show messages:  1-10  …  51-70  71-90  91-110  111-130  131-150  151-170  171-190  …  251-264
26 Oct 2018   [#111]
Silouewette DFX export to modo.
AI export.
26 Oct 2018   [#112] In reply to [#110]
Hi pafurijaz,
> So could you use at this point the normal information being converted into Nurbs?
No, not to get the same surface result that you would see by applying subdivision smoothing in a polygon modeling program.
That information is only used in programs currently for shading, not for controlling geometry shaping. Trying to use it for shaping would make the sub-d surface result in MoI look different than it does in all other programs which would be kind of weird. It's a goal to make the result in MoI behave the same as applying sub-d smoothing in other programs.
26 Oct 2018   [#113]
Hi Chris,
just loaded your MODO .fbx into Silo and ZBrush. In Silo the creases come not through,
but in ZBrush it works!
28 Oct 2018   [#114]
@Michael Gibson
as promised I did the test of MoI under WINE with Nvidia GPUs. And it seems to confirm my findings - with proprietary drivers you get this delayed refresh / state issue.
I've tested it on 3 different workstations (dual Xeon with gtx 980 and gtx 1060, dual Xeon with gtx 1050ti and 1030, i7 with gtx 570) and with 2 different distros (OpenSUSE Leap 15 and Fedora 28). Each time I've installed proprietary driver the issue showed up (no matter distro repo or package from Nvidia site has been used).
With nouveau or when AMD card had been used (got a hold of rx 560 for tests) everything worked normally, no matter Wayland or X11 was running (side note - and damn, it was a joy to use MoI under Linux).
Interesting obesrvation has been made on the first Xeon PC - when I plugged in AMD card AFTER Nvidia drivers were installed first, the issue showed on it as well. Sadly I haven't tested whether it will remain if I remove 2nd Nvidia GPU (to make things clear - even though 2nd Nvidia card was still present it was AMD RX 560 that has been used for display purposes). Something I'll try to check next time.
I really don't know what to make out of this, but maybe someone will :) . At this point my biggest hopes are still for MoI V4 and DXVK (not high hopes though). Can't wait for the release so I could test the demo.
29 Oct 2018   [#115] In reply to [#114]
Hi Przemas, thanks very much for testing it!
I'm not sure right now what I can do about it... Is Nouveau not good enough to use instead of the proprietary driver?
Thanks, - Michael
Message 9100.116 was deleted
29 Oct 2018   [#117] In reply to [#115]
@Michael - will try posting on Nvidia boards. Maybe someone will figure it out.
Nouveau is sadly not an option - I use a bunch of 3d apps where it would be a showstopper (Modo for example). In general because of Nvidia policy and trying to keep everything under their control open source drivers support for their cards is lacking (you simply have to use their proprietary driver if you need good 3d performance).
One of the reasons I won't get Nvidia card for the workstation that needs a replacement. But the one in my pc is too new for a swap. Maybe if I do a bit of juggling between PCs and keep Nvidia GPU only for a vm with pcie passthrough...
Anyways ... hope to get MoI running correctly on my Linux workstation - and I intend to keep on trying ;) .
30 Oct 2018   [#118]
Congrats Michael, this SubDs to NURBS is amazing addition to already great app like MOI.
Thanks.
31 Oct 2018   [#119]
Just to add my test, too :) Have to admit, this is just what I wanted, ability to convert to nurbs at some point, do trims and blends and export back
to polygonal modeling app. Through years, learned to avoid all edge weighting except full sharpness, where result is same as disconnecting. This was only way to have a predictable results anywhere.
31 Oct 2018   [#120]
Here something very interesting, made with blender cloth simulator and SubD into NUBRS, very clean result only edges on boundary of surfaces.
3 Nov 2018   [#121]
The sds mesh to nurbs conversion is a great idea, indeed! Thanks to Micheal for adding such a useful feature to Moi!
Btw, Anto... what tools did you use for producing such a mesh object? Mesh fusion, Hard mesh? Or the new add-on of Blender 'Bevel after boolean'?
3 Nov 2018   [#122] In reply to [#121]
It's an old experiment in Houdini, where everything is created by combining the parametricaly created elements, one frequent element is 'bubble' in pic (it starts from modified circle). Then there are interpolations in NurbS blend style between them, projections to mono-wing (also defined by arcs and blends) or these 'bubbles', so on. In Blender world this could be more in Sverchok category (at least I believe). IMHO, not really approach for meeting the deadlines, because in R'n'D style approach one has to take care about hundreds of additional parameters, conditions and such.
Regarding 'mesh cut and blend' approach, while this is possible mission (and btw I did one for Houdini), I wouldn't count that much on them, anywhere. There's immanent problem of highly subdivided mesh, needed to get the cuts smooth enough. For ratio between bounding box and detail, typical for plane or car, that's really, really unpleasant polygon count. While Nurbs easy can go in such challenge, surfaces are meshed just at the end of the day.
3 Nov 2018   [#123]
Thanks for the reply! : - )
4 Nov 2018   [#124]
I believe that you can ask something like that to the lovers of Elephant by Max Smirnov! ;)
5 Nov 2018   [#125]
Here are some steps to repeat a bug that I don't remember being in V3.
Open a 3DM file and select some curves.
Click the Export icon and notice that the 'File name:' box isn't filled in with the currently loaded file name.
From the list of files in the folder, choose the currently loaded file name.
Change the 'Save as type:' to DXF and click 'Save'.
A warning 'Confirm Save As' box appears stating "xxxxxxx.3dm already exists. Do you want to replace it?"
If you happen to click 'Yes', then your 3DM file is replaced with just the selected curves.
Martin.
6 Nov 2018   [#126] In reply to [#32]
Could you please explain the process you used to prepare the demo soldier as an obj for MoI SubD? How many polygons did you convert it to, and how?
Thank you!
7 Nov 2018   [#127] In reply to [#126]
<< explain the process
Hello
Very simple ;) (this object .OBJ is start quadrangulated)
Use the plugin integrated inside ZBrush call Decimation Master : so you can take any number of polygons as result.
1/10 is normally sufficient - 50 000 polys seams reasonnable
If you have not ZBrush take any free prog like MeshLab: http://www.meshlab.net
Menu Filters / Remeshing, Simplification & Reconstruction... for Decimation
menu Filters / Polygonal & Quadmesh... for Quadrangulation
I don't remember the exact number i will remake it so be patient 10 minutes! :)
32 544 polys as result : loading in 18 seconds inside MOI 3.0 (on my latop Windows 10 - I7 4 years old)
(I must verify if it's vertices, edges or faces because it just write number during the process inside moi! ;)
Verified : it's 32 544 polys! ;)
I will put here the file decimated !
So you can load it directly inside Moi with _importObj by Max Smirnov for make your own test! ;)
http://moi.maxsm.net/media/files/
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/demosoldier.obj
(points = vertices)
8 Nov 2018   [#128] In reply to [#125]
Bump: Just in case it's been overlooked:)
8 Nov 2018   [#129] In reply to [#128]
Hi Martin, sorry I haven't gotten to that one yet, but now with v4 MoI is using the dialog through Qt which should hopefully behave in a standard way.
I was wondering if that's intended behavior or not. I need to check out what other apps do to see if MoI v3 was not doing it as expected or if it's MoI v4.
9 Nov 2018   [#130] In reply to [#1]
The nudge keys are not working. Specifically, the arrow keys and the page up/down keys for moving the selected objects by the grid quantum. When I press the right arrow, for example, I get an alert that says:
SyntaxError: Expected an identifier but found 'Right' instead
line 1
1: >> Nudge Right
I imagine that these functions are implemented with a script, but even so why is this script failing?
Thanks for making v4! FYI, I've got a file with over 5K objects. V3.2 loads it in about 29.5 seconds. V4 loads it in about 3.2 seconds. Wonderful!
Christopher
