Full Version: How to add a curve to a loft?
Show messages: All  1  2-4
24 Sep 2018   [#2] In reply to [#1]
The more simple :
draw your 4 th curve like this you will see exactly where drawing it / existing surface
kill the previous surface lofted
Select the 4 curves
call Loft
Careful : if you select the 4 curves one by one : order is important!
If you select them by box selection normally you will obtain a progressive surface
24 Sep 2018   [#3] In reply to [#1]
Hi Nico, thanks for your purchase!
Currently there isn't any way to add an additional curve to an already completed loft using history. To do that you would need to delete the loft result and make a new one that has all 4 curves in it.
In the future I do want to work on deeper history editing functions but it will be quite a lot of work so I'm not sure when that will happen.
Thanks, - Michael
26 Sep 2018   [#4]
Thank you for your answers.
