Full Version: New Beta version will not open my large files
Show messages: All  1-12  13-20
7 Sep 2018   [#13] In reply to [#12]
Thanks Michael...
Message 9054.14 was deleted
4 Oct 2018   [#15]
This issue is something that I hit quite regularly.
Would it be possible to have the Mesh Angle value displayed somewhere on the ui?
5 Oct 2018   [#16] In reply to [#15]
Hi James, it would be possible to modify the UI to display it, where would you want to put it?
I'd generally recommend not to mess around with that setting much though since it can have bad side effects if set lower than the default 10 degrees.
5 Oct 2018   [#17] In reply to [#16]
Maybe between the options and the help at the bottom.
5 Oct 2018   [#18] In reply to [#17]
Hi James,
So to do that you'll need to edit the file CommandBar.htm which is inside MoI's ui sub-folder.
The options and help buttons are on line 137 of that file and look like this:
				<moi:CommandButton icon="icons/OptionsIcon.png" onclick="if ( event.ctrlKey && event.shiftKey ) { LlamaMode(); } else { moi.ui.createDialog( 'Options.htm', 'resizeable,defaultWidth:43em,defaultHeight:32em' ); }"><moi:Text textid="Options"/></moi:CommandButton>
				<moi:CommandSplitButton icon="icons/HelpIcon.png" menu="HelpMenu.htm" onclick="moi.launchHelp();"><moi:Text textid="Help"/></moi:CommandSplitButton>
To add a display of the mesh angle between them insert this new line in between them like so:
				<div style="display:inline-block; margin:0.5em">Mesh angle:<moi:Text binding="this.innerText < moi.view.meshAngle"/></div>
5 Oct 2018   [#19] In reply to [#18]
Thanks Michael, works a treat!
Message 9054.20 was deleted
