Full Version: Pattern on a Sphere
Show messages:  1-6  7-26  27-46  47-66  67-86  87-106  107-126  …  167-184
27 Jul 2018   [#47] In reply to [#45]
Hi Stefan,
A slightly different approach.
I trimmed a sphere with triangle shapes, then ran transform-deform-twist on the resulting surface. Put a small explodemove on just the trimmed pieces after the twist.
27 Jul 2018   [#48]
Hi BurrMan,
very good idea and looking cool! Now i would copy and paste the edges from the surfaces
and then construct "cutting objects"*, to slice another sphere, to get your nice pattern on
a solid sphere... :-)
I usually create those with duplicating the curves and scale one inwards a sphere and
the other one outside the sphere and loft them, to use the lofted surfaces as trim objects
for a solid sphere.
[EDIT]
Why do i create lofted "cutting surfaces" instead of projecting and then trimming? Because
i often have holes here and there in the solid surface when using complicated patterns.
With "cutting surfaces" i don't have this issue. ;-)
27 Jul 2018   [#49] In reply to [#48]
Hi Stefan,
The object and result was a solid sphere!
I just unjoined and explodemoved it for the visual effect.
So, dice some fundamental pattern on a sphere surface, then "twist" it to get some of those more "Organic shapes"...
The sphere wont deform in a twist on its center axis.
27 Jul 2018   [#50] In reply to [#49]
Before a twist....
27 Jul 2018   [#51]
Hi BurrMan,
Ah o.k.! I only thought when "re-projecting" your nice surfaces you would have than more
space between each surface.
[EDIT] Never mind, i am probably wrong with my thinking and have to try it out myself.
28 Jul 2018   [#52]
Hello :)
...blobs, blobs, blobs! :)
(Moi + Thea Render + Affinity Photo)
...as usual...no uv, no retopo, no texturing.
Ciao!
29 Jul 2018   [#53]
Hello everyone!
...stars on ball!
(Moi + Thea Render)
Ciao!
30 Jul 2018   [#54]
Hi Stefan and Friends ,
It seems that I find it taste .....
Another Pattern (PhylloPattern on Sphere) with multiple outputs,
(see attached images) some concerning the Form and the Volumes,
Others , more the graphic appearance (Colors) .
I hope it is a your liking and maybe a suggestion for as many futures
contaminations ......
Files and images to this link:
http://www.mediafire.com/file/5cykyb2jo0s8lx6/PhylloPatternonSphere.zip/file
If you believe that the topic is interesting, kindly publish it....
Thank you for the great patience you show with me.
Have a nice evening
al
30 Jul 2018   [#55] In reply to [#54]
Hello AL!
Wonderful pattern!!
But...why don't you directly include the final images into the messages that you post?
It's really a pity to be forced to download the zip, extract, then view the images...
Your stuff deserve to be viewed instantly :)
31 Jul 2018   [#56]
Marco, Stefan , and friends, if you do not place my files directly
and related images, it is simply because not
I can no longer do it, as I said,
I do not know if it depends on the Server or what else ...
the fact is that after the seismic events that occurred
in the Marche (Italy), where I live, I could not do it anymore
Sorry, but this is the reality ......
I hope in the future that I can normally post my work
Sorry again , and
Have a nice day to all
al
31 Jul 2018   [#57] In reply to [#56]
Ciao AL!
(Italian)
...ma che strano problema questo dell'update impedito per le foto...stranissimo.
Mai sentita una cosa del genere.
Evidentemente come dici te e successo qualche casino grosso a livello di Server della telefonia...
Spero che presto le cose si mettano a posto :)
English.
Hello AL!
OK. Got it. I hope that soon your internet connection will be restored to its usual behavior.
Ciao!
Message 9014.58 was deleted
1 Aug 2018   [#59] In reply to [#58]
Delicious!
1 Aug 2018   [#60]
Hello everyone!
...not strictly "on sphere" but..."on disc" :)
Moi + 3D-Coat + Affinity Photo (Back image from Pexel)
Ciao!
Message 9014.61 was deleted
2 Aug 2018   [#62] In reply to [#61]
Beatiful!!
2 Aug 2018   [#63]
Hi all,
i am currently busy with non-related 3D things and therefore have no time
to visit the forum daily.
Nice submissions from you all. Keep up the good work!
2 Aug 2018   [#64] In reply to [#63]
Thanks Stefan!
Have a nice day!
3 Aug 2018   [#65]
Hi Friends
Anyone interested can find this link :
http://www.mediafire.com/file/kajf8j19alp8383/TriaPatternonSphere.zip/file
file.nod and picture of
Triangular Pattern on Sphere, in the file I used
my last Macro _Exp Polyhedron
have a nice day to all
al
Ps- Note that the Boolean are really
stable, slow, sometimes very slow, but
they give great results,
notice the quality of the single cut surface
Message 9014.66 was deleted
