85-104
105-124
125-144
145-164
165-184
I am affraid that you must have some files installed before use Elephant Node Editor! ;)
Generally i ask to put all the folder Nodeeditor because there are several versions for be sure to use the .nod posted! ;) ....
After this done...
Maybe you must try some easy things for understand how all that works! :)
Take a look here for a very simple and detailed example (in French - I don't remember if I made the same in English)
http://moi3d.com/forum/index.php?webtag=MOI_FRANCAIS&msg=471.62
(must be readable with a translater! ;)
https://www.deepl.com/translator
Ps Alas i have no time for this special sport for the moment... :(
thank you for your help, much appreciated!
The problem is i have played in the past with Node Editor
and it worked. Now with the Islamic Pattern node the run
button is greyed out and i don't understand why. So it seems
not many people using it and trying out the examples, provided
by community members...
Hi Stefan
You must see if any tools used are highlighted
in Red...
In this case everything is blocked
this means that you have not uploaded the updated features ..
check and let us know
best
alberto
It's for that sort of thing that Post Folder NodeEditor with the file nod is imperative! ;)
As each user has a different one that make a mess for the reader! :)
You right it's not ecologic but it's just less one Mega!
Hi Alberto,
yes, there are some features in red. So i must look now
in all the threads, ever posted, to find these features,
because they are not included with the latest Node Editor?
If thats the case i think it would be best if the Node Editor gang would
have a github page where all those extra files can be looked up, because
the MoI Forum is imho not ideal, compared to other forums, to look for
such things. Well, only a suggestion.
I will look for those missing files this afternoon.
iT'S SO SIMPLE to post the Folder nodeeditor!!!
I don't understand why people don't make that! :)
Hi Stefan
I understand all your reasons, what I can do and attach you
the zipped file that contains all the extensions-
So in your program in the ui folder of your version
you have to replace the entiere Node folder by putting the contents of the zipped file
files at this link:
http://www.mediafire.com/file/u6d4vzd7of76tli/nodeeditor.v.1.0.rc3.2018.03.09.zip/file
Good luck
alberto
Hi Alberto,
thank you very much for your help, much appreciated!
Now it is working! :-)
Best regards
+10000 for this remark from Pilou!!
...I'm telling it for centuries :)
Hi Friends
Always on the theme of Pattern
I'm turning around the polygonal ones
with the possibility to make them flat or in relief
interested parties find this link:
http://www.mediafire.com/file/mn84o80gbo5v9ga/RecursiveOcthagonalPattern.zip/file
files and images
Have a nice day all
alberto
Hello Friends ,
a square base pattern, in relief, applied
to a sphere ....
result 4704 faces to which a color can be applied ...
It seems to me an excellent milestone for our MOI ,
what do you think?
file and images at this link:
http://www.mediafire.com/file/b64bd9s0172og9f/RecQuadPattern-Relief.zip/file
Have a nice evening to all
alberto
Hi All,
Star patern on sphere made possible by Brian's new node.
Can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1452
that's cool. i like the render too.
Wonderful job!!
Hello Friends
a variation of Islamic Pattern applied
to a sphere .
those interested find the file this link:
http://www.mediafire.com/file/li3oh19i9exr3vy/Islamic_P-3.zip/file
best
al
Hi Friends
An interesting, at least I think, pattern on a sphere
files at this link :
http://www.mediafire.com/file/rk869828trdbhct/m1-m2_tiling_on_sphere.zip/file
They are two experiments, similar but different
Have a nice day to all
al
For test the nodeeditor again :)
I took 1/4 of Sphere
Well, not quite a sphere.
Hi Friends
Starting from the file Cosine Bump by Brian
we get this application, editable
with various parameters, on a Sphere ...
thanks Brian ...
file at this link:
http://www.mediafire.com/file/2evnuf5prfmkrzf/BrianBall.zip/file
Have a nice day all
al
85-104
105-124
125-144
145-164
165-184
