The free version is Real Time or not (Maxi 1920 *1080)
You can use it for commercial use!
OBJ or any 3D format like SKP is permited! (for Moi you can use Nurbs formats but not 3DM! )
In the easy 3D Virtual Reality world (works also with a Mouse ;) take a look to
the Free PBR* for free SKetchUP Make 2017 (or Pro) ! Moi exports in SKP file format! ;)
(speedy zooms are insane! :)
By a French guy Samuel
Are you serious about it? is a game engine, although it can be used for rendering, it is not the most suitable for Moi3d users. . it is a Blender fork and the programmer now works for the new version of Blender2.8..And learning how to use the Real-time Rendering engine takes time. The best way is always to use Cycles or wait for the month of October where the new version of Blender will most likely be available.
The KREA interface has changed but the “Real time rendering” function is still there (even in free)
Of course, you can use any program as a source! Even Krea itself, for make a meta AI, doesn't even larsen effect!
I was about to get blender Ducky3d materials...but found out a few days ago that Plasticity has materials as well.
works good for what I need simple and fast. I still think Lightracer is a good price.
Free Simslab render is an very easy traditional render... ;)
But today you can use also this sort of thing! ;)
Free Krea Real Time Screen!
Put any prog on the left Moi3D if it's your favorite 3D prog...
Here double sessions of free Krea Real Time Screen for an infinite Ping Pong creative result!
A sort of double temporal loop creative! :)
With moi 3D in Real time! ;)
Just write a "material prompt" and play with the Strength Slider creativity!
Remark the third wheel, normal it's a concept car! :)
Vizcom in free can be a cool render and modifier for MOi!
Vizcom allows for free exports at 1K, 2K, 4K, and 8K resolutions but not using the Mix function! (just click the image! ;)
Simply click on the image, select the Download icon, and choose "Export"... the processing time will depend on the format! https://moiscript.weebly.com/vizcom.html
Render can be made in 1k, 2K, 4 K but can be also re calculated at export in 8k !
