Full Version: V4 beta Jun-6-2018 available now
Show messages:  1-14  15-34  35-54  55-68
8 Jun 2018   [#15] In reply to [#13]
Thank you for answer.
It was very very annoying for me.
So I reverted my version to previous one.
I hope the new behavior is option instead of default in next version. :)
8 Jun 2018   [#16] In reply to [#15]
Hi sandykoufax, it could help me if I understood why the right click to cancel was useful. If you start the circle command for example, how is it that you then don't want to draw a circle anymore? I mean is it because you meant to actually run some other command and you were in the circle command by mistake? Or is it something else?
You can also cancel the circle command by pushing the Cancel button, using the Esc key or just starting a new command which will cancel the current one.
The main reason for the switch was that now the Open and Import commands will show some UI with a cancel button on it, and right clicking in a viewport would then cancel the file load which doesn't seem good to do.
8 Jun 2018   [#17] In reply to [#16]
Because that it was default workflow for a long time.
Something change give some inconvenience until it gets used to it.
8 Jun 2018   [#18] In reply to [#17]
Hi sandykoufax,
Certainly, and that's why I'll definitely set it up so you can do a one time configuration step and then return to the old behavior after that.
But whether it should be the default or not depends a lot on how much inconvenience is involved in normal usage, like is it once a day, once and hour, once a minute, etc... ?
8 Jun 2018   [#19]
Release notes in first message have been updated. - Michael
8 Jun 2018   [#20] In reply to [#1]
Hello Michael!
@You : "...Update viewport right click - Don't push Cancel buttons with a viewport right click, it's too easy to accidentally cancel a long file import or things like that..."
This is OK for me!
8 Jun 2018   [#21]
French news' List updated! :)
http://moiscript.weebly.com/v4-quoi-de-neuf.html
8 Jun 2018   [#22] In reply to [#21]
Very nice picture again!!
9 Jun 2018   [#23] In reply to [#19]
I have adjusted the grip frames size in the Moi.ini file and much better visibility.
Many thanks
Barry
9 Jun 2018   [#24]
I increased EditFrameGripPixelSize to 32. Much easier to find the frame handles on my widescreen monitor - Thanks!
9 Jun 2018   [#25] In reply to [#1]
IS there any improvements on the Blend command?
Thank you
9 Jun 2018   [#26] In reply to [#25]
Hi Roger,
There are no changes to the Blend command in this beta release.
12 Jun 2018   [#27] In reply to [#9]
Hi Marco,
re: MF2018.STEP file that gets stuck loading at 36% - I've got that fixed up now for the next v4 beta. There was a Solids++ function that could be slow to process certain kinds of trim boundaries. I've rewritten it with an improved version that does not get bogged down anymore.
Thanks for reporting the bug and sending the file for me to test with!
12 Jun 2018   [#28] In reply to [#27]
You're welcome Michael!
Good to know that you have fixed that issue :)
12 Jun 2018   [#29]
Great loading speedup Michael. Massive speed benefits on my DualXeons also.
I got 3x,4x, and even 5x on some STEP models.
Kudos
12 Jun 2018   [#30]
Cool now also imports the colors of the objects, very well, great.
12 Jun 2018   [#31] In reply to [#29]
@Lewis,
Sounds fantastic Lewis, thanks for testing it!
@pafurijaz - yes that Raspberry Pi board that you wrote about previously here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8936.27
should be working ok now.
13 Jun 2018   [#32] In reply to [#1]
Greetings Michael thanks for the great update.
Pardon my ignorance, Please tell me how to use the the numbers followed by (ms) that appear in the upper left of each viewport.
Thanks. Cheers!!
13 Jun 2018   [#33] In reply to [#32]
<< by (ms) that appear in the upper left of each viewport
I believe it's just info for the moment of display's speed between each use of function ! ;)
13 Jun 2018   [#34] In reply to [#32]
Hi phlatt5th,
That's the number of milliseconds it took to draw the last viewport screen image.
It's used to compare the results of performance work to get a numeric measure of whether things are faster or slower instead of just going by feel.
It won't be on for too much longer, just until some last display performance work in v4 is done.
