8-27
28-47
48-60
Thanks Michael! Latest beta works great - no issues.
Take the day off and enjoy this Seattle sunshine :)
Congrats on completing your new update! Thank you sir!
> Seems if i have well seen that there is nothing to translate in the string.txt? (no * at lines' beginning )
Yup, no translations needed for this one. There will probably be some for the next one.
Thanks, - Michael
Thanks everyone - sounds like it's going well so far!
Thanks Michael for this new version.
VERY nice!
just opened the new beta -> all customscripts are working and even the customUI is just there.. no more hassle with different betas like promised
And it runs fine on my iMac 5k (AMD Radeon R9 M295X 4096 MB).
I'm really looking forward for the NEW things you will implement..
Thank you Michael!
Perfect - thank you, Michael
-moritz
Congratulations on the major accomplishment Michael!
Will try it soon.
Marc
Great work ! Thank you !
If you're looking for an idea for new feature, i've got a great one : Export as OpenSubdiv !
That means quads not tris, and nice shaped polys around booleans, so Turbosmooth / openSubdiv can work in polys 3D programs...
I'm quite sure it is impossible, but hey, you are the clever guy, i'm only the user one ;-)
Best regards
Hi naxos, that is something I'd like to work on in the future but it will involve a much different type of mesh generation than the current method. I'm not sure when I'll be able to work on that.
Which new feature will be the next you working on...
Just meddlesomely... ;-}
I can confirm that that special characters OBJ export BUG is fixed.
I tested on heavy model full of those (i reported you only single layer to have smaller test case) and all worked fine, export was quick and model is readable in LW, modo, MAX, no errors :).
That would be the Holy Grail for modellers worldwide : precise modeling, booleans that works, so as chamfers, and to be able to open in a mainstream 3D software for animation, and so on...
As a nice quad-meshed polyset, ready for smoothing...
Nice quad meshes like those :
https://i.ytimg.com/vi/bVzfndz-vPQ/maxresdefault.jpg
https://i.ytimg.com/vi/sh-pwCQMQEs/maxresdefault.jpg
https://i.pinimg.com/originals/89/5a/4c/895a4c75ba28d1015efd3f9a70d3bb66.jpg
Great to hear you have reach this milestone and finally going into new features! I am looking forward to it for sure.
Would be cool to see a list of what is planned for features. I know there was a lot of talks about it before but plans were also changing along the road so, as far as i know, there is still nothing set in stone, so to say. Perhaps now at this point there is?
My suggestion is the same one i already mentioned hundred times and see people asking (and complaining about) hundred times more > better and robust fillets. Fusion360 like fillets flexibility would be dream come true for me. I know, though, it's not that easy so just a remainder. ;)
Best
thanks for the update,
I haven't had the chance to test the other features, but the Mac display bug ist still unchanged, still jaggy jumpy...
cheers from cologne
t.
Hi naxos,
Actually I'm kind of confused by these examples because they all look like things where you'd just put fillets on them in NURBS and then I don't know why you would want to apply additional sub-d smoothing in addition to the fillets.
They all seem to be examples that are so much easier to do in NURBS rather than sub-d.
Hi torsten,
Can you please e-mail me at
moi@moi3d.com and also send your system specs?
I'd like to send you a couple of test builds to see about solving this problem.
Hi Ralf,
I'll probably be trying a few experimental ideas, but I'm not sure if they will work or not.
Hi klaudio,
Sorry no still nothing set in stone. I don't really like to work that way too much. It's probably a good time to try some experimental things which may or may not amount to anything.
I wanted to highlight a problem with the import of a STEP file once imported into Moi all the objects are grouped in the center, with FreeCAD there are no problems. this is also present in version 3. Last thing the STEP files are not assigned colors or layers.
https://grabcad.com/library/raspberry-pi-3-b-1
8-27
28-47
48-60
