16-35
36-55
56-60
Hello Michael,
I am trying the new MoI 3D version. That's really great. Especially when I saw the possibility of the new OpenGL option. I tested it right away. So I put GraphicsAPI=OpenGL in the moi.ini file.
And, there, it's great, navigation with a 3D mouse is really faster on large files.
However, I have the same problem as Bernhard.
I can no longer select anything; neither curves, nor objects, nor surfaces.
For information, I work with Windows 10 Pro V1803.
One Gigabyte GTX960 4GB graphics card, one Wacom Intuos 3 tablet and one Xeon X5472 CPU
Daniel
Hi Daniel, you might try updating your video driver to the latest version available and see if that makes any difference. It's probably best to get it directly from nVidia's web site.
One other thing you might check is in your video card system settings, if anti-aliasing is forced on there it can interfere with selection, it should be set to something like "application controlled".
If neither of those help then you'll have to stick with Direct3D11 for now, but possibly if I can solve the texture readback problem on Wine it may solve it for your case as well.
I am getting very slow viewport feedback when rotating, selecting etc in larger models. I loaded up the same model in 3.1 and I get much a faster / smother response. I am using OS X 10.123.4 with a Radeon Pro 580 graphics card.
-Shane
Hello Michael,
Thank you for your answer.
I took your advice:
1) To update the video card, I have the latest version from nVidia.
2) Following your advice, I did some tests in the nVidia control panel. I went to 3D Settings / Manage 3D Settings / Program Settings.
There, I added the MoI 3D V4 executable to make modifications only for MoI 3D.
Then I disabled the first three Antialiasing lines: FXAA, Gamma Correction, Mode.
The most important to disable is FXAA Antialiasing.
By disabling these parameters, normal volume and curve selection is possible in the 3D View.
However, in the other three 2D views (Top, Face and Right) the selections do not work for the curves and work randomly for the volumes.
I hope this information can help you with debugging.
Otherwise, I'm running in DirectX mode.
And I look forward to the new version and of course the new features of the V4.
Sincerely,
Daniel
Hi shane,
Can you please e-mail me at
moi@moi3d.com and I will send you a test version with some changes that may help.
Thanks, - Michael
16-35
36-55
56-60
