Full Version: Zarkow’s Sub D
Show messages:  1-2  3-22  23-42  43-47
10 Aug 2023   [#43] In reply to [#42]
The Node Editor can stay open. Just change surface selections.
Slow this down on YouTube
https://moi3d.com/forum/index.php?webtag=MOI&msg=10756.19
11 Aug 2023   [#44] In reply to [#43]
ok..Run the first time....Stop ... Apply ...Clear/Update (for input a new the selection)... make the trick..
even direct selection don't work for me...
But for go out the node for use the result i must use this (not a big deal)... is that the same for you ?
script:/*go out nodes*/ var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true );
11 Aug 2023   [#45]
seems not working on a complete native sphere!
12 Aug 2023   [#46]
LineWeb + CMorph can also be a canditate for facetting when you know the number wanted of the divisions edges curves side! :)
And will works where JFHSubd entangles for strange surfaces :)
12 Aug 2023   [#47]
PS Quads generated on the Zarkow's car are specially planar or not ?
