Full Version: Zarkow’s Sub D
Show messages:  1-11  12-31  32-47
6 Mar 2023   [#32] In reply to [#31]
Right-click on the node, a menu will appear, choose what you need.
7 Mar 2023   [#33] In reply to [#30]
Psygorn, James first shared his works, but then deleted them.
Max was also available at first, now the site is not working.
I think we should go our own way, but it will end sometime.
If you have the desire and the time, do it.
7 Mar 2023   [#34] In reply to [#33]
I have the desire, but I don't have the knowledge and skills!
7 Mar 2023   [#35] In reply to [#34]
Psygorn, the knowledge and skills of those guys that I mentioned above and many other smart people also did not appear by themselves.
As long as there is a desire, then everything will be fine.
7 Mar 2023   [#36]
Hi Psygorn
I changed your node a bit.
See if it helps.
449_test.nod
8 Mar 2023   [#37] In reply to [#36]
Hi MO_TE,
That's interesting thank u!
Message 8916.38 was deleted
8 Mar 2023   [#39] In reply to [#33]
It was not the case that there was a wholesale deletion of my archive of demos, but rather I was continuously freeing up space before each new post because I quickly reached the limit of my forum data allowance.
I moved my NE demonstrations to instagram in large part due to this frustration, but also to evangelise for NodeEditor & MoI3d to a wider audience . My motives were purely out of self-interest: I thought if we could grow the user-base for NodeEditor, it would accelerate its development.
Obviously, instagram posts don't have the facility for attachments, but as apparent here, the issue of NE uptake & version inconsistency invariably meant that often my .NOD files did not work for others.
I have long felt that I should take the reins of this project and finally get it out of beta phase, but I have been too busy to devote the necessary time, and not being a coder, it is not something I could do alone. I still have great faith in NE.
8 Mar 2023   [#40] In reply to [#39]
images in background are well sliding so we can see the nodes graph !
but no comfortably! :)
8 Mar 2023   [#41] In reply to [#34]
Hi Psygorn.
Experiments.
https://disk.yandex.ru/d/Wer8NUYikdYXrg
9 Aug 2023   [#42]
JFHSubD2
Does this the normal use ?
Select a surface
Load the Node ...Run
Select another surface
Load the Node...Run
etc...
10 Aug 2023   [#43] In reply to [#42]
The Node Editor can stay open. Just change surface selections.
Slow this down on YouTube
https://moi3d.com/forum/index.php?webtag=MOI&msg=10756.19
11 Aug 2023   [#44] In reply to [#43]
ok..Run the first time....Stop ... Apply ...Clear/Update (for input a new the selection)... make the trick..
even direct selection don't work for me...
But for go out the node for use the result i must use this (not a big deal)... is that the same for you ?
script:/*go out nodes*/ var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true );
11 Aug 2023   [#45]
seems not working on a complete native sphere!
12 Aug 2023   [#46]
LineWeb + CMorph can also be a canditate for facetting when you know the number wanted of the divisions edges curves side! :)
And will works where JFHSubd entangles for strange surfaces :)
12 Aug 2023   [#47]
PS Quads generated on the Zarkow's car are specially planar or not ?
