Full Version: Zarkow’s Sub D
Show messages:  1-18  19-38  39-47
7 Dec 2022   [#19] In reply to [#10]
Hi Psygorn (DRILLBIT).
You can also revive an old file. There is a file in the archive 'objects3.js ' extract it to the folder where your 'Nodeeditor' is located.
In many macros from this forum, you will encounter nodes from this file. For example 'Concat2'.
I attached this file at the bottom.
image host image host
objects3.js
8 Dec 2022   [#20]
Hello guys,
Thank you all for your help and guidance.
However, I am in need of your help again.
Please take a look at the attached file. I tried to retopologize the surfaces you would find in the attached files they are named: "1" "2" & "3" surfaces "2 and "3" are joined surfaces (so they consist of two sub surfaces)
When I try to use either JFHsubD.nod or JFHsubD2.nod I cannot get a good retopologized surfaces out of surfaces "2" and "3" if there is a solution to this problem I would by happy if u let me know what that is! :-)
Best,
Psygorn/Drillbit
JFHSubD_Problem.3dm
8 Dec 2022   [#21] In reply to [#20]
Hi Psygorn,
it does not work on joined surfaces also the surfaces must have 4 edges only.
You can rebuild your surfaces with network.
Also set 'U' and 'V' to the same as some times the surface U V are opposite.
Barry
8 Dec 2022   [#22] In reply to [#21]
Tanx Barry-H
2 Mar 2023   [#23] In reply to [#12]
Hi PILOU,
Do you have older versions of Nodeeditor? Where can I get them? Most links refer back to Max's original blog and you know it's almost a year that his weblog is out of reach!
Best,
Psygorn(Drillbit)
5 Mar 2023   [#24] In reply to [#23]
Hope this can help you...
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/nodeeditorss_for_psygorn.zip
but seems best to use the last by James...
https://moiscript.weebly.com/install-elephant.html
5 Mar 2023   [#25] In reply to [#24]
Thank you PILOU,
For anyone who can help (especially James or WN) ->
I have a question: instead of Idselect and concat what should I use?
6 Mar 2023   [#26] In reply to [#25]
Hi Psygorn.
Depends on what needs to be done. Show the file or drawing of your task.
It happens that the problem can be solved in different ways.
6 Mar 2023   [#27] In reply to [#26]
Hi WN,
I wanted to recreate one of James works here: https://www.instagram.com/p/CY6P8lDr0tW/
But I did not end up with the same results I think it is because of concat2 that I used in my Nod file.
449.nod
6 Mar 2023   [#28] In reply to [#27]
concat2 shows as red colour indicating its obsolete in my nodeditor.
You can replace it with the basics concat node and right click on it to change its operation to numbers.
Delete the concat2 node as the nodeditor will not run with obsolete nodes present.
Barry
6 Mar 2023   [#29] In reply to [#27]
Hi Psygorn.
The "concat" node only collects the numbers in the order of connection and passes them on, in this case it does not matter whether it is old or new.
Most likely, the "MathPts" node has formulas and they are visible only in the properties widget.
I do not know this formula.
There is also a 'mode' setting in the nodes it also affects the result.
image host
image host
6 Mar 2023   [#30] In reply to [#29]
Hi WN,
I had this idea to recreate what James has done on his instagram, and then latter share it with others who want to study nodeeditor and nodes ; but now I think it would be a very hard task! Maybe only james can share his works!
What do u think?
Also, I tried to put the parametric formula for "trefoil knot" in Mathpoints node but it still doesn't give me what I want (Jame's Instagram post). (check the attached node file)
449.nod
6 Mar 2023   [#31] In reply to [#28]
I used Concat node but I cannot even get it connected to the following nodes: Math & MathPts.
6 Mar 2023   [#32] In reply to [#31]
Right-click on the node, a menu will appear, choose what you need.
7 Mar 2023   [#33] In reply to [#30]
Psygorn, James first shared his works, but then deleted them.
Max was also available at first, now the site is not working.
I think we should go our own way, but it will end sometime.
If you have the desire and the time, do it.
7 Mar 2023   [#34] In reply to [#33]
I have the desire, but I don't have the knowledge and skills!
7 Mar 2023   [#35] In reply to [#34]
Psygorn, the knowledge and skills of those guys that I mentioned above and many other smart people also did not appear by themselves.
As long as there is a desire, then everything will be fine.
7 Mar 2023   [#36]
Hi Psygorn
I changed your node a bit.
See if it helps.
449_test.nod
8 Mar 2023   [#37] In reply to [#36]
Hi MO_TE,
That's interesting thank u!
Message 8916.38 was deleted
