15-29
Hello everyone!
If we talk only about EDGES/Curves (and not faces or other things), I think that maybe you could be interested in using my custom command "FilterCurvesByLength"
I use it a lot when I want to select similar edges/curves in one shot!
Here's the demo video :
http://take.ms/mDpcW
And here's the link to the original post, please read it carefully :
http://moi3d.com/forum/index.php?webtag=MOI&msg=8608.20
And here's an example screen capture :
Enjoy ;)
re Michael:
> Hi klaudio, can you post an example model?
It's just a example model to showcase the feature, simple cylinder and then created circle and use Circular Array - boolean difference - done.
re mkdm:
> If we talk only about EDGES/Curves (and not faces or other things), I think that maybe you could be interested in using my custom command "FilterCurvesByLength"...
Interesting! I'll give it a try and see how it goes a bit later. The edges selection is indeed needed in like 99% of the time so faces selection is not that important.
I am curious, does this script has a feature where you can select one edge (or few continuous edges) and then in the script to get it's length + select all other edges with the same length? It would be handy to have that option to get it like that instead of tweaking min and max slider until you get the right edge. Do you know what i mean?
exmpleModel.3dm
You have also these scripts by Michael
script: /* Select by Lenght */ var min = 1.0, max = 5.0; var crvs = moi.geometryDatabase.getObjects().getCurves(); for ( var i = 0; i < crvs.length; ++i ) { var crv = crvs.item(i); var len = crv.getLength(); if ( len>= min && len <= max ) { crv.selected = true; } }
You can input your owns values!
script: /* Select Biggest */ var curves = moi.geometryDatabase.getObjects().getCurves(); var maxlen = -1; var maxcrv = null; for ( var i = 0; i < curves.length; ++i ) { var crv = curves.item(i); if ( crv.hidden || crv.locked ) { continue; } var thislen = crv.getLength(); if ( thislen> maxlen ) { maxlen = thislen; maxcrv = crv; } } if ( maxcrv != null ) maxcrv.selected = true;
script: /* Select Smaller*/ var curves = moi.geometryDatabase.getObjects().getCurves(); var minlen = 1e100; var mincrv = null; for ( var i = 0; i < curves.length; ++i ) { var crv = curves.item(i); if ( crv.hidden || crv.locked ) { continue; } var thislen = crv.getLength(); if ( thislen < minlen ) { minlen = thislen; mincrv = crv; } } if ( mincrv != null ) mincrv.selected = true;
Hello Klaudio!
@You : "...I am curious, does this script has a feature where you can select one edge (or few continuous edges) and then in the script to get it's length + select all other edges with the same length? It would be handy to have that option to get it like that instead of tweaking min and max slider until you get the right edge. Do you know what i mean?"
Yes, I mean.
No, actually there isn't a feature like that because I've stopped the developing of that plugin some times ago because I'm very busy at work and I can't put again my hands on it.
But...maybe also the actual implementation of my custom command can easily allow you to achieve what you want to do.
Follow this little video tutorial based on your model :
http://take.ms/BN9QV
I often use the that trick. I hope the it can be useful also for you.
Ciao!
Hi klaudio, thanks for posting the example model. So for many cases you can use the already existing function of window selection to select many edges in one action, you aren't limited to selecting edges one by one by clicking only.
The way it works is you select just one edge to start with - once one edge or face is selected then a window select after that will similarly target edges or faces. Also window selection works in 2 different ways depending on whether you drag towards the left or the right. Dragging towards the left will target things that cross any part of the window while starting on the left and dragging towards the right will only target things totally contained inside of it.
Here's how it works using your file:
Hide, Lock and Inverse Selection can be also a very big help!
You can also hold down Ctrl while doing a window selection to do a deselection window instead of selection window. One other trick is if your screen is all filled up so it's hard to find a blank area to start the window you can hold down Shift+Ctrl, that will force window selection to happen anywhere and disable the regular click selection.
Michael I do think that Marco's script can be very useful as to the thing that I did mention (I learned about its existence just now) but, still, I think that a very simple 'select same' command would be very helpful: you just select a curve, an edge, a face or an object and then click 'select same' and, there, you have selected all the same curves, edges, faces or objects in the working space!
Below I am putting a simple explanatory image. What we do in such a case when we do want to select all the similar faces -as the selected one- on such an object (other than selecting them one by one)?
In this case it's very easy!
Select All Faces on the Panel Type (click on the empty end line)
then with Ctrl + Selection right to left in some Views 3D or not depending of the complexity of object
Of course that is valuable with your simple object shown, will be more difficult with a StarWars' starship! :)
Thanks for taking the time for explaining but as i mentioned before i already know all about selection methods in Moi, all of them are extremely useful and and i use them all constantly. Beside the ones you have mentioned i also often like to use method where i add object or/and its edges/faces only into browser by give it a name. After duplicating the object you have saved selection set you can always easy access. Or also sometimes by assign different color to object or components.
Still there are just a lot of cases where you simply can't drag select objects or it's components because of complexity of the objects and their positions. The example above from Rainydaylover is still simple but it is a good more complex situation. You could drag select (from left to the right) couple of times to get only faces but that will work since it's simple model with just face at the end but often might have added a bevel or something else which means you can't drag select thing but only select one by one.
For example like this, you want to select all faces on the top to use Inset, no way but to just pick them individually.
Always for your object shown
Assuming that your faces are 3 * 3
script: /* Select by length */ var min = 3.0, max = 3.0; var crvs = moi.geometryDatabase.getObjects().getCurves(); for ( var i = 0; i < crvs.length; ++i ) { var crv = crvs.item(i); var len = crv.getLength(); if ( len>= min && len <= max ) { crv.selected = true; } }
Select all Edges by Type Panel
Copy Move the Edges somewhere in the 3D Space
launch the Script
Construct Planar : you have your faces selectect :)
Will work for a StarWars StarShip!
Hi Dimitri, When you have a question or example please post the 3DM file containing the actual geometry instead of only a screenshot. That helps because then I can make sure I'm using your same objects to test with and to answer your question.
You can use window selection as I described above, you do not have to select them one by one. Start by selecting one face to make the window selection target faces.
In this case I'd switch to split view and use left-to-right "only target fully contained" window selection like this:
Hi klaudio,
That's a pretty unusual example, because I would usually expect to see the fillet placed after doing the inset, not before.
But just as you described if you do a little bit of planning you can solve that problem and not be required to do individual picks if you use the window selection method before doing the filleting. That way there aren't little fillet surfaces in the way and then assign a name or style to those faces which will persist after filleting. Then they can be selected by one click in the scene browser and you are not required to pick them with individual clicks.
Thanks for the detailed explanation Michael, I would never imagine that there is such a way of selecting similar items in a scene! : -)
That's so cool - great to know how that works.
15-29
