25-44
45-64
65-84
85-104
105-124
125-144
145-164
185-200
Wow this is a big help - great screen shots - that's such an excellent method. Thanks I will post my version in "newbie learning the ins and outs of MOI"
Thanks again Barry!
Here is my attempt at the fillet method - started from scratch with this and used a new headstock design which kind of screwed up the mating of the lofted neck and headstock - but it's solid and good for a first try. Thanks Barry - will keep practicing this method - very clever indeed.
Hello VEGASGUITARS.
Thanks for sharing!
I don't know which method did you use to build the model but that are issues as you can see :
Regards.
Thanks for pointing out that mistake.
Hi Neil,
Try moving the seam.
Barry
How's this one Barry? :)
Hi Neil,
looks good your on the way.
Barry
Barry, Yay! Thanks very much for your patience and great advice. I really like the way you model - very clever ideas! There are so many things you can do with Boolean commands - very cool stuff.
N
Here's a guitar I just finished for a customer in Phoenix - hand made from scratch under one roof by a crotchety, snaggle tooth, good ball. BTW I also hand wind all our pickups too. :)
Great work Neil!
Hi Neil,
I have managed to get a good result using a simple network, trim and blend into head.
I would like to try it on some different heads before posting the process.
So if you have any curve drawings of heads you can share can you post them to me.
Barry
.png)
Wonderful job!!!! Congratulation!!!
Hey that looks fantastic Barry - really awesome. Have a couple been working on that will send - also a .dxf of a LP for something different. Looking forward to seeing what you do with the other files too. - Neil
Hi Neil,
got the files will look at them Monday as I'm away the weekend.
Barry
Lookin' good Barry!
Nice Neil! Hand wound pickups too, sweet.
M
Great advice Barry - thanks much!
Hi - sorry I didn't reply earlier. Yes I own two CNC machines. As you mentioned it seems the best neck transitions are done with filleting, blending, networking - and Boolean operations .. . unfortunately I have a long ways to go until I'm past the "learn your basics" stage - but its fun anyway!. Nice to know there is another hand builder around here you can appreciate what's involved. If you ever want to mill something let me know. Thanks a lot for your input.
Hi Neil,
here is the method I have been using with network & blend.
I'm still looking at lespaul head it may require a different method.
Hope this helps.
Barry
Wow - excellent - that is really clever - and looks fantastic. Have to get to work on that. Many thanks Barry! Trimming spheres that is so cool. I'll bet I wont be able to duplicate your work. I'm still having trouble reliably repeating trim and blend. :)
25-44
45-64
65-84
85-104
105-124
125-144
145-164
185-200
