Full Version: Guitar neck and arch top methods
Show messages:  1  …  102-121  122-141  142-161  162-181  182-200
27 Nov 2018   [#162] In reply to [#161]
Thanks Marco!
30 Nov 2018   [#163]
Here's the first 3D body done with the new machine - of course it will look better after finishing. Ruined a few pieces of cheap wood before getting the CAM portion correct. The neck was not cut for the contoured heel but rather a standard heel - will do the contoured one in the model shortly.
Message 8883.164 was deleted
26 Jun 2020   [#165]
(removed spam)
15 Aug 2020   [#166] In reply to [#165]
Latest guitar modeled in Moi - small body semi-hollow arch top coming soon.
16 Aug 2020   [#167] In reply to [#166]
Beautiful!
16 Aug 2020   [#168]
that's really nice. you seemed to have got the hang of MoI. you're website is nice too. i hope you have a lot of success.
16 Aug 2020   [#169]
Great work Neil! Something very satisfying about creating an object in MoI and bringing it to reality via CNC (and a lot of hand finishing :)
17 Aug 2020   [#170] In reply to [#169]
Amazing work and professional photo lighting.
Mik
27 Aug 2020   [#171] In reply to [#170]
Thanks everyone for the kind words. Can't take credit for the photo as the pictures are by a professional photographer who is also a customer.
Message 8883.172 was deleted
Message 8883.173 was deleted
25 Dec 2020   [#174] In reply to [#33]
Great advice - thanks!
26 Dec 2020   [#175] In reply to [#173]
Hi Neil,
> There is a guy selling tutorials on how to model guitars in Moi3D here: https://3dcncguitars.com/
That's great, I didn't know about this one! I've added a link from the MoI resources tutoriuals page.
That would easily be worth it to get very specific information on a complex area like this.
26 Dec 2020   [#176] In reply to [#175]
Still a novice - but have learned a lot via this forum about guitar modeling. When a little further along I'd like to share, in a concise file, the tips and tricks accumulated over the years from here so that others, interested in the area, will have a solid foundation to get started with and then expand on. Certainly can save the beginner some grief.
26 Dec 2020   [#177] In reply to [#176]
Here is an arch top made with a different program that was shared on a CNC web site - any ideas how one could do this with Moi?
26 Dec 2020   [#178] In reply to [#177]
Hi Neil, that one seems to be built in a "patch by patch" type method where some profiles were drawn in and several surfaces probably constructed using a sweep or network type tool. One problem though with this kind of patchwork method is it's hard to get a totally smooth result. For example this area has a sharp edge:
It tends to be hard to get really good quality smoothness using this type of approach. But it is overall a pretty difficult thing to model.
Often times something organic where you would need to do a patch-by-patch approach can be handled better by sub-d modeling instead of NURBS modeling for those areas.
26 Dec 2020   [#179] In reply to [#177]
Hi Neil, so this surface is planar so that's probably a good one to construct first from planar profile curves:
Then this area here:
I'd probably try making an extended sheet something like this using Sweep or Network:
Then that would get trimmed by a profile curve like this:
And then these areas would be done with a Construct > Blend.
You could get a large portion of it built like that but then the rounded tip protrusion like spots will be the most difficult to do well.
neil_arch_top3.jpg  neil_arch_top4.jpg  neil_arch_top5.jpg  neil_arch_top6.jpg  neil_arc_top_planar.jpg
26 Dec 2020   [#180] In reply to [#177]
Hi Neil, so this method would go something like this:
Planar curve here - build a surface from it using Construct > Planar.
Another planar curve on the interior like this:
Cross sections running in this direction, slightly curved:
Construct > Loft through those to make this type of extended surface:
Trim the loft with the interior curve:
Trim edges with lines to break them:
Select edges and do a Construct > Blend:
That would be a good way to start out I think getting an initial chunk of it done.
neil_arch_top10.jpg  neil_arch_top11.jpg  neil_arch_top12.jpg  neil_arch_top13.jpg  neil_arch_top14.jpg  neil_arch_top15.jpg  neil_arch_top7.jpg  neil_arch_top8.jpg  neil_arch_top9.jpg
26 Dec 2020   [#181] In reply to [#177]
Then probably the next steps would be to build these strips that rise up from the planar base level:
