Full Version: Guitar neck and arch top methods
Show messages:  1-16  …  77-96  97-116  117-136  137-156  157-176  177-196  197-200
9 May 2018   [#137] In reply to [#136]
Awesome! Thanks for the clarification. Just thought that area might be a mistake. Looking forward to trying that option you pointed out - very cool program you have here. So hopefully will be posting some pictures of this neck in wood soon. It might be interesting for some to post pictures of the CAM tooling layout. Usually the tooling is done in 2-4 cycles. In this case - one 2D session for the contour (outline of the neck) & tuning key holes and then a 3D session comprised of roughing and finishing of the 3D surface. - N
9 May 2018   [#138] In reply to [#137]
Hello VEGASGUITARS.
Yes! as Michael suggested a G2 Blend do the trick!
Wonderful job!
Congrats again :)
25 May 2018   [#139]
Huge thanks to all the experts here sharing their advice and ideas - was able to mill a pretty good neck profile out of cherry. Photos and video posted on the thread for tummy and arm contours.
27 May 2018   [#140]
Here is the second round milling a neck profile with the CNC machine. This is a different model - it has a Tele style heel and Strat style headstock. The tool paths are better and machining time is cut in half - this took 45 minutes and an additional 30 to cut it out with the band saw then sand with the random orbital. The methods used for the model are a combination of Jopo's and Barry's. Also the drawing would not be possible without help from quite a few folks here especially Michael. Can't tell you what a relief this machine is going to be - long time coming - it has mostly sat since I built it. Honestly after milling this - almost broke down seeing how smooth the headstock transition turned out . . . :) No more breaking my back and hands with the rasp and spoke shave.
https://youtu.be/fSVgXcwMZwU
27 May 2018   [#141] In reply to [#140]
Very good!
..I'm wondering how those guitars will play!!
When you have completed the final product, please post some sound samples!!
28 Jun 2018   [#142] In reply to [#140]
Saw this go by awhile back. Just finished up and am back on my computer for some undetermined amount of time...
Made a quick video of Barry's model and take. Added a few steps to show how to change the transition rates by extra trimming before the blend. Too much bulge and you'll fold over or wrinkle...
Anyway.....
28 Jun 2018   [#143]
Cool as usual Burr!
M
29 Jun 2018   [#144] In reply to [#142]
Awesome man - thanks for sharing!
19 Jul 2018   [#145] In reply to [#35]
Hello,
Been practicing the method Barry posted with the added pointers from BurrMan and am starting to get some nice results. Thanks again for all the great tips and ideas. The necks get better and better thanks to you guys.
12 Sep 2018   [#146]
Pretty happy with the latest neck for the Riviera and Ione models - the transitions are getting sleeker and more gradual. These are done using a combination of techniques learned here - especially Jopo's. Still have to get better at working with solids. The networked necks are done well enough now to make solid. Looking forward to milling this neck - the top of the neck is not done because it's faster to do the fretboard and headstock face by hand using jigs. Thanks for taking a look. Also many thanks to those who gave a hand with learning the ropes - still not there yet but progress is always encouraging. This is by far the best forum in terms of sharing of information and project assistance I've ever seen. Would imagine that's mainly because the writer of the program is so hands on it's astonishing. Some days it's like everything falls into place - other days I have to shut it down because it seems impossible. Anyone else experience that?
12 Sep 2018   [#147] In reply to [#146]
Looking good Neil! Things will continue to get more comfortable as time goes on.
26 Sep 2018   [#148] In reply to [#1]
If you're building a neck-through or set-neck instrument it's very important to have a detailed cross-sectional drawing or full-size plans for the instrument. The neck angle relative to the instrument's top, and the top's shape or contour along with fingerboard and fret height, must be taken into account and designed to work with the bridge height. If it's your first attempt at a new design, be sure to have the bridge, truss rod and all other hardware nearby. This will let you know the ranges of application for these components, as well as how they will fit together. You must provide adequate access to the truss rod, and the bridge must be adjustable within the intended string height range determined by the neck.
Don't make your truss rod channel too big or too deep, especially in the peghead/volute region. This will weaken the neck, making it susceptible to neck breaks or the truss rod punching its way out the back of the neck.
https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
28 Sep 2018   [#149] In reply to [#148]
Thanks much for the input. While new to modeling and CAD/CAM not new to guitar repair or building - that's how I make my living. Started repairing professionally in 98 and built my first guitar around 2006 and have built many guitars and basses since. You can check some of em out here : vegasguitars.com - the slide show on the main page has quite a few guitars and basses - neck through, set necks and bolt-ons.
Thanks again for the suggestions - can always stand to learn new and better ways to do things in even though I'm an old codger. CAD/CAM has been a struggle to learn - but it's beginning to pay off in a big way around the shop.
Message 8883.150 was deleted
24 Oct 2018   [#151]
A few folks asked to see the finished neck - am finishing the body too and will post next week. This neck was modeled entirely in MoI and milled using Estlcam.
24 Oct 2018   [#152] In reply to [#151]
Wonderful!!
Congrats!!
24 Oct 2018   [#153] In reply to [#151]
Looks great!
31 Oct 2018   [#154]
Here is the completed project - the guitar body, pickguard and neck are modeled in MoI then milled, finished and assembled here. It was custom ordered by the lead singer in the "Bee Gees Gold" show. He asked for that pickguard (not my first choice). It is chambered and only 1.5" thick. The body is alder and the top, neck and fingerboard are curly birds eye maple. Thanks for all the help - without which making this with a CNC machine would not have been possible so soon. The rear lower pickup rout on the model looks a little misshapen because it is designed for both the humbucker and the traditional pickup - which fits in the pocket sideways. The tops are routed for either. There are three neck designs for this instrument - each one has a little bit larger profile (the round part where you put your hand) to suit different tastes. The middle one was used for this guitar. FYI Made the pickguard by gluing some drum wrap material to a piece of thin acrylic - then milled a template with the machine - then used the template to route the pickguard complete with bevel. After routing the pickguard sprayed the back flat black so the acrylic edge would show up and match the switch knob and o-rings on the volume and tone control knobs. Thanks for taking a look.
31 Oct 2018   [#155] In reply to [#154]
Words.....
31 Oct 2018   [#156] In reply to [#154]
Looks fantastic Neil, thanks for posting the pictures of your finished project! You've got up to speed on 3D CAD quickly.
