Full Version: Little Tips & Tricks :)
Show messages:  1-15  16-35  36-55  56-60
28 Feb 2018   [#16] In reply to [#15]
Hello Michael.
I repeated the test and I've found maybe a strange behavior, but I don't know if I'm doing something wrong or not.
It's something I can't figure out.
Please check this brief video : http://take.ms/nuPqd
This is a textual explanation, but it's better to check the video.
1) I created a box 50x50x50 with a circular fillet of 10
2) I tried to "offeset" one single surface (without separate from the body)
3) AS YOU CAN SEE THE FILLET DOESN'T WORK
4) This time I created the same box 50x50x50 but with a g2 fillet of 10
5) I tried to "offeset" one single surface (without separate from the body)
6) AS YOU CAN SEE IT WORKS!
I stay tuned. Thanks.
28 Feb 2018   [#17] In reply to [#16]
P.S. The same identical behavior happens if I use the "Inset" command.
On Circular fillet doesn't work
on G2 fillet it works.
28 Feb 2018   [#18] In reply to [#17]
Hi Marco, that's a bug in V3 that has already been fixed in V4. The bug had to do with the fillet corners for the circular case not creating an analytic sphere surface class. When you save and reload the file it does get a specialized analytic sphere surface type for the corners and that's what makes the different behavior in v3.
According to my notes it was reported by Pilou last year through e-mail and I fixed it on May 22, 2017 so all released versions of v4 should have the fix in it.
Same thing there as well - should be fixed in v4 already.
28 Feb 2018   [#19] In reply to [#18]
@You : "...Same thing there as well - should be fixed in v4 already..."
Perfect Michael!
Tested on V4 and it works!
I was not aware of this behavior.
Thanks and have a nice day.
28 Feb 2018   [#20]
Variation of the Chipp Walters Tip! ;)
28 Feb 2018   [#21] In reply to [#20]
Very nice!
28 Feb 2018   [#22]
Hello everyone!
My two cents for a little Voronoi trick to get all things with filleting in two shots.
Works very well on simple Voronoi.
Check this video : http://take.ms/YNCkl
Ciao!
28 Feb 2018   [#23] In reply to [#22]
bravo !
28 Feb 2018   [#24] In reply to [#23]
28 Feb 2018   [#25]
About Voronoi :)
Just a boolean operation for inside any figure! :)
1 Mar 2018   [#26] In reply to [#13]
Thanks for the "select Edges > Merge > BlendCap" addition, Finema. Hadn't thought of that alternative yet.
1 Mar 2018   [#27]
As a form like this can't be SuDivided directly (Top face more than 5 edges)
All Plugins by Max Smirnov
Use SSPlit for trim
Use SBridge for "Blend Faces" only 2 by 2
Use _SUbD for SubDivide
Copy / Move faces
Bridge them
Extrude to Point or Nsided (Kill the caps before) can be used for simple form :)
4 Mar 2018   [#28] In reply to [#2]
Hello!
SubD trials in Pilou's instructions. Tried to draw upholstery parts of a chair with SubD. It is necessary to rethink something, because the result is not yet visible when the initial form is created.
I created this one from a cuboid and used "bridge" for the "nose" in front of the seat. Then I noticed that once you split the surfaces with Split or Iso, you get points in the body that can be moved. In this way, it is possible to get closer to the desired shape and achieve the desired "upholstery effect".
Thanks for the help, you can see, it'll be all right.....
4 Mar 2018   [#29]
With the new _Voronoi by Max Smirnov:)
Take 2 sets and use the ISect Boolean Function! ( whith Union Sets disabled )
then ExplodeMove hidden function
Have fun!
Here twice the same but you can take any things! :)
4 Mar 2018   [#30] In reply to [#29]
Cool!!
Thanks a lot for this tip.
5 Mar 2018   [#31]
Wow, thank you very much for this tip.
5 Mar 2018   [#32] In reply to [#29]
That's quite a cool technique, Pilou, thanks for sharing!
6 Mar 2018   [#33]
have you seen this at ZBCentral? :-)
6 Mar 2018   [#34] In reply to [#33]
Yep! Boozy was an old ZB artist friend of the golden age! :)
6 Mar 2018   [#35] In reply to [#33]
Pilou and I are trying to get Boozy to hop on board over here. He's a really sympathetic chap.
