17-23
Thanks to both of you.
I'm currently runnin as admin, and its working fine.
I will try what Anton suggested too.
Hello guys anyone please can help when I try to add object from my object library the pivot point for the object in difrint place not in the object center anyone have idea why? Thank you in advance
Load object, set a cplane, and re-save?
Thank you bemfarmer.
Hi MOI users, I am having the same problem where the object folder won't let me add anything to it. I had a bit of a struggle just getting the Custom UI to work. So I am trying to figure out what I did wrong. In reading this post on. How to set up the object library. Sure sounds like I un-zipped the file one layer to deep. Wonder if anyone could explain what I should do. I read this post over and over. But just wanted to see if anyone could steer me in the right direction. Thank you for any tips.
Hi Specktech, can you show a screenshot of the directory structure that you've set up?
Also what operating system are you running on?
Try running MoI as Admin.
17-23
