10-29
30-49
50-69
70-81
Hi Pilou!
I tried to insert the older version sSplit. v. 0.6.2015.03.26 with a renaming to sSplit_old next to the new version.
But only the newer version works, maybe something would have to be changed in the files sSplit_old. The old version would have the additional effect that you could work with equal values for a cube (10,90 or 30,70) to get a symmetry.
(Because of missing snaps).
We can't thank Max enough, I agree.
This forum is full of extraordinary people.
Franz
Seems I use also the last version of 2015 ;)
http://moi.maxsm.net/files/scripts/sSplit.v.0.95.2015.08.10.zip
Hi Pilou!
Before I have not seen the counter, so I can also reach symmetry.
That's actually enough.
Thanks for the tip with the points shift, it is getting better and more controllable. Great!
Franz
Hi Pilou and Franz,
just figured out that the free SurfMill 8.0 Pro has in it's NURBS modeler module
also a Deformation palette, with a lot of flow commands.... ;-)
And a new UI too! :-)
http://bbs.jingdiaosoft.com/forum.php?mod=viewthread&tid=5056&extra=page%3D1
gif image hosting
So after ArtForm ...SurfMill !
it's endless... :)
This is different, or improved over ArtForm?
...And same Installation ?
@Chris it has the Deformation palette, which ArtForm does not have.
I am also not quite sure why they have SurfMill with the same modules
as ArtForm, maybe it is more specialized in the CNC module, i don't know.
@Pilou it is the same installation procedure. Very easy. :-)
Ah yes the same Chiness headache! :)
Hi Stefan!
Thanks, I already got it down here.
Now I only have to play with it.
I think I need a course...
Franz
Hi Franz,
yes, that is a little problematic to have an (English) course...
If you like to learn sculpting with it then you have to watch
the many JDPaint tutorials on Youtube or youku.com. To bad
that only people in China, Vietnam and Russia are using the
software, which makes it difficult to understand the tutorials.
Hi all,
just figured out that ArtForm can now also be downloaded from
their European site. :-)
For installation of ArtForm Pro 3.5 it redirects however to their
Chinese website forum.
https://eu.jingdiao.com/product-technology/software/jdsoft-artform
10-29
30-49
50-69
70-81
