4-23
24-43
44-63
64-81
Hi Franz, excellent! :-) Now you only need to input your Username in the first (white) field and your Forum Password in the second (white) field. After that click the button below the fields and then the software should start in English. SurfMill is not required for registration, it's an additional Software for creating Router Paths for CNC Machines.
P.S. should the Software not start in English i post a screen shot were you must look for the menu switch.
Will be fine if you could make some snap shot screen of each step !:)
... according to the description of Stefan.... 8815.11
http://bbs.jingdiaosoft.com/forum.php
Hope I can help with this screenshots:
(You get a Email after register, landing often in the spam)
Now I'm here, but I have to learn how to use the program.
Imported the Moi drawing in IGES format to be processed in ArtForm 3.5. However, not yet the success as Stefan in the step "merge".
Let's see now. I need some more time.
And at the last page register (if success) what button to Press at the end ?
Edit success register but now
it should be the little blue button below the Captcha code. The other two buttons, the big blue and big green are for other network media registration, if i remember correctly. Like QQ (large blue button) a chinese service, similar when you register at sites via a Facebook account.
@Franz currently i can't help because i'm busy at work, but it looks like you have not merged the corners. I did it that way that i merged the corners with their sides first and then merged the other sides with the top surfaces and at the end merged those large stripes as one surface.
Registering : success! :)
<< Once you have access to the forum (the original Chinese page) and downloaded the
software
what button for Download the prog ? :)
like i said before you have to carefully read Chris posting (click the link)... There you will find at the first posting at the bottom a login and download link.
Hope this helps.
Hi Franz,
this technic may give you what you want.
I joined your curves and ran the rebuild command on them.
Networked the top face. Extruded the base shape with no caps.
Blended the top to the bottom with a 1.2 bulge.
Blend corner blend to blend not base.
Joined all and ran planar to cap bottom.
Hope this helps.
Barry
I am connected on the forum (as shown by the little guy right to the white ring bell)
but when i click the Blue button of download with white Arrow the same page is back again!
Same result on these 2 pages! So what is your secret ? :)
Hallo Pilou!
I think I have done on the first one. May be I choosed the text with ArtForm3.5, dont know exactly.
But at the moment I can't make a login myself, because I don't know about the security question.
I dont remeber to give any security answer while I registered.
Unfortunately you can't copy the text, so I tried it with a text recognition program from the image.
But unfortunately no success, because I don't know my security question, I am sorry.
http://www.i2ocr.com/free-online-chinese-simplified-ocr
Hi Franz and Pilou,
sorry that i cant be of assistance. I downloaded it long time ago and it seems that the procedure
may have changed a bit. At least i never had security questions, only the Captcha thing with the
two chinese characters in the past, but this might have changed too?
Seems the security question is optionnal because that don't block your login to the forum !
Thanks Stefan, it's just the weird letters...
Well, if you've managed to be in the forum,
then press the text JDsoftArtForum 3.5 under the download button.
Then you get to the download page, just scroll down to the bottom and download....
Here some screeshots:
A long run race! :)
Wishing now that the 2 parts unzip well :)
Of course there was a last trap!
be carreful!!!
The install program don't build a name folder so all folders / files go directly in the Programms file folder
so a new mess! :)
Launching the prog i have that! :)
Seems my tribulations are not finished! :)
Edit : That Work : input User Name / Password of the Forum register! ;)
My first chiness thing! :)
and now new headache for export that! :)
Hi Pilou!
Look at this:
8815.23
and the answer of stefan.
Have fun!
... now I also have found the correct entry of login ...
Yes I found the trick in the previous minutes! :)
Now the hunting convert files 3D is open! :)
Seems all is built on a plan ?
So a tore is an half tore! (?)
Seems vs3d format is the best way! :)
ArtForm Pro has four modules (or rooms) you can work in.
You are currently in the first. If you go to the third module/room
you have access to ArtForm's Surface NURBS modeler were you can
import .3dm files from MoI or export from there as .iges.
The other modules are used for drawing, like in Illustrator or
for sculpting 2.5D reliefs. The fourth module is for setting up
paths for CNC machining etc.
If you want to learn sculpting 2.5D reliefs i suggest you look
at Youtube videos about JDPaint. ArtForm is the successor
of JDPaint and is compatible.
Seeing speedy the video this morning i have believed that was separated progs! :)
Cool that all is inside! :)
So no problem of export to Moi or import! :)
4-23
24-43
44-63
64-81
