Full Version: Drawing a shape, but how?
Show messages:  1-13  14-33  34-53  54-73  74-81
11 Feb 2018   [#14] In reply to [#13]
Thanks Stefan, looks great.
12 Feb 2018   [#15]
@Pilou It is not so difficult if you open up a second window in your Browser and use Google Translator... :-)
@chrisd I think they did that because their Enterprise version of ArtForm was one version lower
and they simply unified the numbering scheme for both versions.
@Franz Thank you, maybe you can use it.
12 Feb 2018   [#16]
and the UI is also in Chiness ?
12 Feb 2018   [#17]
The registration pop-up menu is in chinese, but the software switches to english menus.
12 Feb 2018   [#18]
here is a screenshot of the NURBS module in ArtForm Pro 4.0.
Hope this helps.
12 Feb 2018   [#19]
Don't find the Forum for registering! :(
(even with the Translate :)
12 Feb 2018   [#20]
click on the translated link from Chris... and read carefully the English translation
from the first post. There you will find at the bottom of this post a link to register
and a link to login for the download.
12 Feb 2018   [#21]
P.S. In case registering does not work with the translated page, due to CAPTCHA's etc.
use in the first Browser window the original Chinese page. As CAPTCHA there come up
two Chinese characters, which you see and which you have to click in the right order.
Once you have access to the forum (the original Chinese page) and downloaded the
software look at the pop-up menu for a line with two input fields, one for your
Username and one for your password. Once the software accepted your input the
software should start then in English.
Hope this helps.
12 Feb 2018   [#22] In reply to [#21]
A chiness headache maze! :)
12 Feb 2018   [#23] In reply to [#20]
Unfortunately, the Chinese ways are also complicated for me...
Here I am, but cannot start...
Do I need the software JDSoft SurfMill 7.0 for registration?
12 Feb 2018   [#24]
Hi Franz, excellent! :-) Now you only need to input your Username in the first (white) field and your Forum Password in the second (white) field. After that click the button below the fields and then the software should start in English. SurfMill is not required for registration, it's an additional Software for creating Router Paths for CNC Machines.
P.S. should the Software not start in English i post a screen shot were you must look for the menu switch.
12 Feb 2018   [#25]
Will be fine if you could make some snap shot screen of each step !:)
12 Feb 2018   [#26] In reply to [#25]
... according to the description of Stefan.... 8815.11
http://bbs.jingdiaosoft.com/forum.php
Hope I can help with this screenshots:
(You get a Email after register, landing often in the spam)
12 Feb 2018   [#27] In reply to [#26]
Now I'm here, but I have to learn how to use the program.
Imported the Moi drawing in IGES format to be processed in ArtForm 3.5. However, not yet the success as Stefan in the step "merge".
Let's see now. I need some more time.
13 Feb 2018   [#28] In reply to [#26]
And at the last page register (if success) what button to Press at the end ?
Edit success register but now
13 Feb 2018   [#29]
it should be the little blue button below the Captcha code. The other two buttons, the big blue and big green are for other network media registration, if i remember correctly. Like QQ (large blue button) a chinese service, similar when you register at sites via a Facebook account.
@Franz currently i can't help because i'm busy at work, but it looks like you have not merged the corners. I did it that way that i merged the corners with their sides first and then merged the other sides with the top surfaces and at the end merged those large stripes as one surface.
13 Feb 2018   [#30] In reply to [#29]
Registering : success! :)
<< Once you have access to the forum (the original Chinese page) and downloaded the
software
what button for Download the prog ? :)
13 Feb 2018   [#31]
like i said before you have to carefully read Chris posting (click the link)... There you will find at the first posting at the bottom a login and download link.
Hope this helps.
13 Feb 2018   [#32] In reply to [#1]
Hi Franz,
this technic may give you what you want.
I joined your curves and ran the rebuild command on them.
Networked the top face. Extruded the base shape with no caps.
Blended the top to the bottom with a 1.2 bulge.
Blend corner blend to blend not base.
Joined all and ran planar to cap bottom.
Hope this helps.
Barry
13 Feb 2018   [#33]
I am connected on the forum (as shown by the little guy right to the white ring bell)
but when i click the Blue button of download with white Arrow the same page is back again!
Same result on these 2 pages! So what is your secret ? :)
