Full Version: Drawing a shape, but how?
Show messages:  0-19  20-39  40-59  60-79  80-81
10 Feb 2018   [#1]
It is a positive mold for thermoforming plastics.
I have tried many ways, now I am on this result.
I have connected individual surfaces with network and flat surfaces to form a body.
But the body should look even more "grinded".
Does anyone have a better way to get a seamless surface?
Is there a possibility with the methode of subdivision?
The drawing file is attached.
Form.3dm
10 Feb 2018   [#2] In reply to [#1]
Hi Franz, a few ideas in these previous threads:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1002.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=3137.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6134.1
Subd could be a good idea too.
10 Feb 2018   [#3]
Remember this race and the number of possibilities! :)
Good luck! ;)
10 Feb 2018   [#4] In reply to [#1]
Hi Franz,
I used the script _Pillow32Web.
Rotated a copy 90 degrees.
Joined the outer edge curve to a square and fillet it, then split at the rounded corners.
Hid the next curve in (4 total).
Did Network on all the non-hidden curves.
(I'm out of posting space)
10 Feb 2018   [#5] In reply to [#4]
<< (I'm out of posting space)
https://servimg.com/?lang=en
10 Feb 2018   [#6] In reply to [#5]
Thanks PILOU!
11 Feb 2018   [#7] In reply to [#6]
Thank you for the many suggestions.
There is a lot to try now, unfortunately I have no experience with SubD.
It would be nice if you could simply apply SubD based on an existing surface.
Anything else should be difficult.
The Pillow script with loft is great, but has no solution for the round corners.
Michael's approach with sweep 1002.12 is interesting, but not easy.
If necessary, then bring the flat body with flow to the curved shape.....
I will report if there is a better result in sight than my previous one.
11 Feb 2018   [#8]
Hi Franz,
my humble approach with the free ArtForm Pro 4.0 Software.
form_merged.3dm.zip
11 Feb 2018   [#9]
P.S. i only merged your surfaces... and did not start with a fresh modeling technique described
by Michael's links.
11 Feb 2018   [#10]
< free ArtForm Pro 4.0 Software
Have you a link to this ?
11 Feb 2018   [#11]
i no longer have the link.... But when you look at their Web site
you can check their BBS Forum Link for ArtForm Pro 4.0.
But you have to register at their Forum in order to download the
Software and also register the Software with your Username and
Password.
http://www.jingdiao.com/en/researchcapacity_en/softwarefield-en/jdsoft-artform_en.html
11 Feb 2018   [#12] In reply to [#11]
Thx but seems very complex to register in Chiness ? :)
11 Feb 2018   [#13] In reply to [#12]
This is very interesting. There is a translated page that says ArtForm 4.0 was renamed to 3.5. How many developers would reduce/regress their version number?
https://translate.google.com/translate?hl=en&sl=zh-CN&u=http://bbs.jingdiaosoft.com/forum.php%3Fmod%3Dviewthread%26tid%3D38&prev=search
11 Feb 2018   [#14] In reply to [#13]
Thanks Stefan, looks great.
12 Feb 2018   [#15]
@Pilou It is not so difficult if you open up a second window in your Browser and use Google Translator... :-)
@chrisd I think they did that because their Enterprise version of ArtForm was one version lower
and they simply unified the numbering scheme for both versions.
@Franz Thank you, maybe you can use it.
12 Feb 2018   [#16]
and the UI is also in Chiness ?
12 Feb 2018   [#17]
The registration pop-up menu is in chinese, but the software switches to english menus.
12 Feb 2018   [#18]
here is a screenshot of the NURBS module in ArtForm Pro 4.0.
Hope this helps.
12 Feb 2018   [#19]
Don't find the Forum for registering! :(
(even with the Translate :)
12 Feb 2018   [#20]
click on the translated link from Chris... and read carefully the English translation
from the first post. There you will find at the bottom of this post a link to register
and a link to login for the download.
