57-76
77-96
97-116
117-136
137-156
157-163
Hi Michel,
i just retried my example and yes it does keep the name so its not as reproducible as i thought.
But if i select the unnamed face first and join it then it is named "box" which is still wrong.
I've noticed this issue some time ago but if no one else has it then its probably something wrong with my setup.
I'll look into it some more when i have a chance and I'll let you know.
Dinos
Hi
I can reproduce it sometimes on V4 OSX but it's OK on V3
Hi dinos, there is indeed a bug there - the bug is that a cached older version of the objects can be used by the moi_commandprocessor.exe worker process and that means that recently applied changes to names and styles can end up being ignored. It's a little finicky to reproduce because the first time you try it there aren't any cached objects and so the current object goes through and it works ok. You've got to get a mismatch between properties on your current objects and cached objects in order for it to reproduce.
It's another manifestation of the styles bug that Brian reported here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8814.81
I've been working on a couple of different possible fixes for the next beta.
Thanks for reporting it!
Hi Finema,
Yeah it's a new bug in V4 because of a new function in V4 where the worker process keeps hold of objects that were recently sent to it so they don't have to be resent by interprocess communication.
Thanks for the explanation.
I was about to write that after trying again on the original test I also got the problem...
Michel
thanks for the explanation and it does make a lot of sense why it was so difficult to reproduce.
Its note a huge issue for me and i'll definitely keep using the V4 beta as my primary version of Moi3d.
Dinos
Just bumping this because I wasn't able to locate it in the thread: Will there be another beta round for 4.0 or is there a scheduled release date now?
Hi J, there will be a few more v4 beta releases yet, there isn't a scheduled final date right now.
In version 3 , the MacBook pro trackpad behaviour for "pinching" and "two finger sliding" is the same. It zooms in/out.
Same also under Windows version 4 beta.
In version Mac 4 beta , by default, the trackpad zooms in/out when "pinching" and pans with "two fingers sliding" but whenever the Mvt, Rotation or Center View control is used, the pan with "two fingers sliding" behaviour changes back to Zoom in/out behaviour and it's not possible to go back to "two fingers panning".
Hope it's not a too obscure description of the problem,
Michel
Hi Michel, it sounds like a bug that I do have fixed for the next upcoming beta - the bug is triggered on Mac if you do a 2-finger drag but start the initial gesture with one finger in a different window than the viewport (the view controls panel is actually a separate window), then drag over and add the second finger inside the viewport without ever having lifted up the first finger.
If it is the same bug then it should be fixed in the next beta release, please let me know if it isn't. I'll be trying to wrap up the next beta in the next week or so.
Yes. It seems to be that bug.
I'll check for it in the next beta.
Thanks for the answer,
Michel
Hi, Michael. It's me again and MoI error.
This time the problem of the cursor and the text field.
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=89b5fd0f63cfca99b625903a58d1896f&filename=cursor.mp4
Vladimir.
Hi Vladimir, thanks for reporting this and showing it. I can't seem to get it to happen over here but I will keep trying.
Does it happen only to that particular text field or have you seen it happen with other ones too?
About all I can't say, but where I watched there it was.
This is well seen where one input field.
Perhaps a shift in focus of the cursor relative to the input fields?
If possible, I would like to know what program you use to create a video from the screen?
Vladimir.
Hi Vladimir, I use Camtasia by TechSmith for doing screen captures.
For little part of screen (for not big files result to send on the Net) you have little free true gem!
GifCAM
http://blog.bahraniapps.com/gifcam/
The reluctance of the little popup window to appear also occurs on my Windows7, with wireless logitech mouse. Nice keyboard mouse combo, MK735, from Costco.
(Same reluctance with USB wired mouse.)
Sounds like this might be a different bug? The problem that Vladimir is showing in that video is that the mouse cursor isn't changing to the "text field" I-beam shape.
Could you please give a little more description of what you're seeing?
Is the "little popup window" you're talking about the "Edit size" one that normally shows up when you click on the size line in the properties panel?
In MoI4FebBeta: Select a line. In the upper right of the screen, left or right click on the Length field, (not on cm). The Edit box appears. So far everything is OK.
Right clicking in the Edit box only occasionally brings up the box with (cut/copy/paste/delete/select all) (Which I guess are Windows7 commands.)
(Similar result for circle or ellipse Edit box.)
In MoI3 Right clicking in the Edit box brings up the cut/copy/... box right away.
(I do get the I-beam shape OK.)
Hi Brian, yup I can reproduce yours over here - thanks for the additional details! I will investigate it.
I can also get part of what Vladimir showed which is the Cut/Copy/Paste context menu shows even when clicking slightly outside the edit field.
57-76
77-96
97-116
117-136
137-156
157-163
