Full Version: V4 beta Feb-9-2018 available now
Show messages:  1-4  …  45-64  65-84  85-104  105-124  125-144  145-163
12 Mar 2018   [#105] In reply to [#104]
Thanks Ralf for figuring it out!
So if I remember correctly in MoI V3 and prior there was a pt.get() function set up but it was only callable from C++ code and not JavaScript code because it took 3 pointer values which JavaScript is not able to express. However just the presence of that method happened to have a side effect of pt.get not being a syntax error in v3 although it would not actually do anything useful.
In v4 the script interface is no longer based on IDL/IDispatch/COM Automation to be cross platform and the new interface only supports constructs that are compatible with JavaScript so the pt.get() method has been removed in v4.
12 Mar 2018   [#106] In reply to [#105]
Much appreciate the explanation - even if I don't quite understand how I interpreted the documentation to arrive at my bad code in the first place :)
- Hamish
12 Mar 2018   [#107] In reply to [#100]
Thank you Michael.
I bought "The Nurbs Book."
Now I just have to read it...
16 Mar 2018   [#108]
Hi
The latest Mac Wacom driver (6.3.29-6) appears to have resolved the middle button issue, great!
Marc
16 Mar 2018   [#109] In reply to [#108]
Hi Marc,
Over here this driver version isn't behaving well, I seem to get kicked out to the login screen when trying to use the middle button with the pen.
If that's not happening to you maybe it's just on older systems or something.
17 Mar 2018   [#110] In reply to [#109]
Hi Michael and Marc,
Just installed the 6.3.29-6 driver, and everything works fine here.
17 Mar 2018   [#111]
Me too.....
19 Mar 2018   [#112] In reply to [#109]
That's odd, I'm using 10.12.3.
It still works well after a few working sessions.
Marc
20 Mar 2018   [#113]
I've been using the Feb 9 beta since it was released and i'm mostly happy with it.
Yesterday i noticed a bug that i'm not sure if it's been reported or not:
- When i Join a named part with an unnamed i would expect it to retain the name, if the named part was selected first. This does not always happen with V4.
I've narrowed it down to a reproducible example, a simple box, separate it, join all sides except one, name it Box and then select the last surface(unnamed) and join it.
The box ends up being named Unnamed, rather than box.
Hope it helps!
Dinos
20 Mar 2018   [#114] In reply to [#113]
hi,
is that on osx?..cos i can't reproduce it here on win 10 pro. cube stays "box".
20 Mar 2018   [#115] In reply to [#114]
Hi Marco, yes, its in osx.
Dinos
20 Mar 2018   [#116] In reply to [#115]
Hi Dinos,
I'm on osx too (10.9.5) and, here, the object keeps box as name when the unnamed face is joined to the others.
Michel
20 Mar 2018   [#117] In reply to [#116]
Hi Michel,
i just retried my example and yes it does keep the name so its not as reproducible as i thought.
But if i select the unnamed face first and join it then it is named "box" which is still wrong.
I've noticed this issue some time ago but if no one else has it then its probably something wrong with my setup.
I'll look into it some more when i have a chance and I'll let you know.
Dinos
20 Mar 2018   [#118]
Hi
I can reproduce it sometimes on V4 OSX but it's OK on V3
20 Mar 2018   [#119] In reply to [#113]
Hi dinos, there is indeed a bug there - the bug is that a cached older version of the objects can be used by the moi_commandprocessor.exe worker process and that means that recently applied changes to names and styles can end up being ignored. It's a little finicky to reproduce because the first time you try it there aren't any cached objects and so the current object goes through and it works ok. You've got to get a mismatch between properties on your current objects and cached objects in order for it to reproduce.
It's another manifestation of the styles bug that Brian reported here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8814.81
I've been working on a couple of different possible fixes for the next beta.
Thanks for reporting it!
20 Mar 2018   [#120] In reply to [#118]
Hi Finema,
Yeah it's a new bug in V4 because of a new function in V4 where the worker process keeps hold of objects that were recently sent to it so they don't have to be resent by interprocess communication.
20 Mar 2018   [#121] In reply to [#120]
Thanks for the explanation.
I was about to write that after trying again on the original test I also got the problem...
Michel
20 Mar 2018   [#122]
thanks for the explanation and it does make a lot of sense why it was so difficult to reproduce.
Its note a huge issue for me and i'll definitely keep using the V4 beta as my primary version of Moi3d.
Dinos
27 Mar 2018   [#123]
Just bumping this because I wasn't able to locate it in the thread: Will there be another beta round for 4.0 or is there a scheduled release date now?
27 Mar 2018   [#124] In reply to [#123]
Hi J, there will be a few more v4 beta releases yet, there isn't a scheduled final date right now.
