Full Version: Extend line ?
Show messages: All  1-5  6-10
5 Oct   [#6] In reply to [#5]
Perhaps simply selecting points and then using Scale 1d?
5 Oct   [#7]
Draw a Circle by center from the last point of a curve with the radius of length wished!
If it's 3D Curves
draw a troncated sphere for have a surface as boundary! :) See : https://moi3d.com/forum/index.php?webtag=MOI&msg=8735.9
For 2D Curves :
Select the curve
Draw a circle by Center with radius length wished
Call function Menu Edit / Extend
Click Circle
6 Oct   [#8] In reply to [#5]
Hi SebKaine, if it is a line that you want to extend by a specific distance you can do that in MoI by selecting the line, then click on the line's length value which is displayed in the properties pane in the upper right area of the window:
That will open the "Edit size" menu and you can increase the length by a specific value by entering in a + sign before the value like this:
6 Oct   [#9]
If it's 3D curves... draw a troncated Sphere from Last point point of curve as center and radius as length wished...
then call Menu Edit / Extend
Click Curve, Click Sphere
Et voilĂ ! :)
20 Oct   [#10] In reply to [#8]
After 8 years of using MOI I had no idea you could change line length, but more importantly, circle radius and rects after drawing the initial curves. I'm trying to not think of all the times I deleted circles and redrew them just to get a different size... perhaps I should read the manual one of these days.
