Show messages: All
1-2
3-10
Hi Bruno, currently the regular Extend command in MoI can only extend to a boundary. I do want to add more functionality to Extend in the future but for now I'd recommend just drawing a line at the end of your curve and joining it to the original curve.
Great! Thanks Michael. I am enjoying Moi quite a lot.
Hi , is it still the case ?
i am searching for the equivalent of the maya extend curve feature.
https://help.autodesk.com/view/MAYAUL/2027/ENU/?guid=GUID-08E73E34-DEAE-4E5B-98DA-CFB4560C06E8
basically
- you select a curves.
- you enter wich part you want to extend ( start, end or both )
- you enter the distance of the extend
- you enter the continuity method
is there an alternative in Moi 3D ?
Perhaps simply selecting points and then using Scale 1d?
Draw a Circle by center from the last point of a curve with the radius of length wished!
If it's 3D Curves
draw a troncated sphere for have a surface as boundary! :) See :
https://moi3d.com/forum/index.php?webtag=MOI&msg=8735.9
For 2D Curves :
Select the curve
Draw a circle by Center with radius length wished
Call function Menu Edit / Extend
Click Circle
Hi SebKaine, if it is a line that you want to extend by a specific distance you can do that in MoI by selecting the line, then click on the line's length value which is displayed in the properties pane in the upper right area of the window:
That will open the "Edit size" menu and you can increase the length by a specific value by entering in a + sign before the value like this:
If it's 3D curves... draw a troncated Sphere from Last point point of curve as center and radius as length wished...
then call Menu Edit / Extend
Click Curve, Click Sphere
Et voilĂ ! :)
After 8 years of using MOI I had no idea you could change line length, but more importantly, circle radius and rects after drawing the initial curves. I'm trying to not think of all the times I deleted circles and redrew them just to get a different size... perhaps I should read the manual one of these days.
Show messages: All
1-2
3-10
