27-46
47-66
67-86
87-106
107-126
127-146
147-166
167-176
@You : "...When a command like that is running, it should still be cancelable,...
I just tested over here and I can't reproduce an uncancelable fillet, I'd need to get an example file that demonstrates the problem in order to find out any more about what's going on..."
Hmm....this is strange...
I can confirm that more than a couple of times I found myself into the problem I described...
Ok. ASAP I try to recover one of those files where I had the issue and I will let you know.
Stay tuned.
Yes, latest Wacom tablet drivers are installed. Wacom tablet type is Wacom Intuos Pro Medium size.
Hi Metin, do you know the specific model number of your Wacom?
I see for the Wacom Intuos Pro that there's a new model number PTH660 that's out and the older model number is PTH651 . I'd like to try and get the exact same model you have so I can test it over here.
Thanks, - Michael
Hi Marco,
That's definitely not the expected behavior, you may experience a short hiccup while objects are transferred over into moi_commandprocessor.exe but nothing at all like the long freezing you are describing.
Since it's not the usual behavior I will definitely need to get an example file where it's happening so I can examine it over here.
My computer at work was behaving sluggishly today. Nothing to do with MoI, maybe with slow telephone wire internet.
The repair man tells me that the "wires down the street were poorly spliced," so I got a new wire...---Old infrastructure.
Is there a recommended software to run on a Windows computer to "tune it up," or find out why it performs poorly?
Even my xfinity fast cable internet service at home decided to quit working for brief periods over xmas.
Maybe too many people playing games?
I'm not aware of any single fool-proof one myself. Probably the standard thing would be to look for spyware/adware, try ADWCleaner, Spybot Search & Destroy, SUPERAntiSpyware, Malwarebytes Anti-Malware, and HijackThis. Be careful where you get these from.
You can also run msconfig.exe and see what is starting up automatically, if you've got a whole ton of stuff on there uninstall or disable things you don't actually use.
Sometimes Anti-Virus software can hook into so many things it can greatly degrade system performance so you can try disabling that.
Also run Task Manager and click on the CPU column under the Processes tab and watch that for a minute and see if there is something that is chewing up a lot of CPU.
Ok Michael.
I understand that you need a 3dm file to test.
But unfortunately today I'm very busy at work and I didn't find a bunch of minutes to find the 3dm file that caused the issue...
I will try my best to find it and send to you.
If I remember correctly when I had the issue I was performing a Fillet command on a messy geometry.
I was doing nothing serious, only a quick and dirt 3D doodle while I was waiting the compiling of my AndroidStudio projects.
So maybe I've discarded the model after the crash.
I will try to reconstruct what I was doing to replicate the issue.
Have a nice day.
Thanks Marco, I can wait until you find it. If I sounded urgent it's just because you yourself described it as a very serious problem and it sounded like it was happening frequently to you. It is sort of frustrating for me to hear that there's a serious problem but having no steps to reproduce it or any examples of the behavior at all.
Thanks, - Michael
I can fully understand Michael :)
It is sort of frustrating for me also not to be able to replicate this very sporadic issue I had.
I don't know what I can say.
I had this strange issue only a couple of times but as I said it happened while I having a little break during my daily job
and many times I do things so quickly that i'm pretty sure I discarded the model and I went back to my job.
I never had any kind of issue like this with Moi and also V4 is fine.
So, don't worry :)
I did so many things quickly and about some weeks ago that for sure I'm getting confused.
I will continue to try to replicate the issue but if I will not find the file you can forget what I've said and not worry about it.
In that case evidently I've made some strange operation or my mind is confused :)
Marco (mkdm)
Thanks Marco, if you run into it again certainly it would be good to know! But yes please, concrete examples are absolutely vital. Of course I want you to report bugs so I can fix them but at the same time it's not so good to report a sort of "theoretical bug" that you just think is likely to happen based on extrapolation from some other information. That's because when you raise a big alarm about a pervasive and serious bug it makes me stop everything else that I am doing and try to reproduce it over here.
If you just have a worry about whether something like canceling a fillet is not going to work anymore in v4 because of those scripting changes it's probably better to ask a question about it.
Hi Michael.
I tried many times to reproduce the issue I described, but without results.
@You : "...That's because when you raise a big alarm about a pervasive and serious bug it makes me stop everything else that I am doing and try to reproduce it over here..."
I apologize Michael!!!
I know what you mean. I'm so sorry... :(
Evidently it was my mistake!!
I really don't know what to say :(
This is the very first time I say a thing here on this forum that I can't prove.
Usually I don't write anything that I can't prove with a real 3dm file.
As I said, many times I do things so quickly during my job break that next time it's better that I save the 3dm file and annotate precisely what I'm doing.
This time I simply remembered that some weeks ago I had an issue while trying to cancel a Fillet command but evidently I'm wrong.
I apologize again.
Forget what I said in my previous posts.
If you want you can also delete all the messages that today I've written about this "hypothetical" and unproven issue.
No problem for me.
Maybe it's better you do so.
Ciao and have a nice day.
I've got the Wacom Intuos Pro Medium PTH660.
Hi Marco, it's ok - don't worry I know that you're just trying to help make MoI better!
Just next time it would be good not to raise the alarm quite so quickly. The messages don't need to be deleted, they will be fine.
Thanks, - Michael
Thank you for understanding, Michael!
It's ok!
@You : "...Just next time it would be good not to raise..."
Message received :)
Have a nice day.
Ciao!
Hi Metin, re: Wacom middle mouse button only works after an initial left click - I went and got the same model tablet over here and was able to reproduce the same problem. After digging into it, it appears to be a Wacom driver bug. I was able to also reproduce the same problem in a simplified separate test case project that just makes a window and displays what events it is receiving and it never receives any drag events if the first thing you do is middle click and drag, but it does get them (although actually with a wrong event type) if you do a left click before doing the middle button drag.
So I'm fairly sure that it's something that has to be fixed in the Wacom driver and not in MoI. I've sent in a bug report using their contact form with the minimal test case project code attached.
If you also want to send in a bug report to Wacom to increase the chance that it will reach someone who can fix it, send in the attached .zip file which contains the test case and the bug report can say:
Subject: Missing or incorrect middle mouse drag events on Mac
Note minimal test case xcode project attached.
Bug #1 - if the first thing you do is try to middle click and drag inside the window, no drag events are sent, only otherMouseDown on press and otherMouseUp when released. Drag events for middle button dragging are only sent if you have done a left click at least once previously.
Bug #2 - when drag events for middle mouse drag are sent after having once done an left click, they are sent as mouseDragged (left button) events and not otherMouseDragged events.
Expected results - drag messages should be sent when the middle button is clicked and dragged same as left/right buttons without requiring an initial left click and they should be sent as otherMouseDragged events rather than mouseDragged events.
Test case is a minimal window/view that sets the window title text when it receives mouse events.
Tested on XCode Version 7.3.1 (7D1014), OS X El Capitan 10.11.4 (15E65)
Wacom Intuos Pro Medium size PTH660
Wacom driver version: 6.3.27-2
Wacom configuration - only setting changed from default is setting the upper barrel button to Middle Click.
Thanks, - Michael
WacomTest.zip
I saw "WACOM pen bugs" with other software here, and a support link:
http://forum.wacom.eu/viewforum.php?f=6
http://www.wacom.com/en-us/support/contact-support
Is this pen tablet a useful tool?
Thanks Brian!
It's particularly useful for artists who have spent a lot of time using a regular pen or pencil for drawing, it gives a lot closer feel to that then using a mouse.
I downloaded V4 today after buy v3 and it also seems to work with Linux in Wine HQ. You're a great one!
Hi pafurijaz, that's great - I'm glad v4 is working for you in Linux Wine!
What video driver are you using in Linux?
Hi, Michael, some more clarifications:
In my laptop and desktop PC I have Ubuntu 16.04.3 LTS
The Graphics Card on laptop: Intel(R) HD Graphics 5500 (Broadwell GT2). Mesa DRI Intel(R) HD Graphics 5500 (Broadwell GT2)
In the other desktop machine I have a the little GeForce GTX 750Ti and moi v4 works even with this card. And with this nvidia proprietary drivers
27-46
47-66
67-86
87-106
107-126
127-146
147-166
167-176
