Full Version: V4 beta Dec-12-2017 available now
Show messages:  1-5  6-25  26-45  46-65  66-85  …  166-176
12 Dec 2017   [#6]
French Site Updated
http://moiscript.weebly.com
@Michael (just a little very cosmetic error from my part) (3 times in French "objects" must be "objets" tiny isn't it! : escaped till now! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/frenchstrings.zip
12 Dec 2017   [#7]
Thank you Michael for your persistent bug eliminating. Mac full screen mode works fine in OS X 10.9.
-Martin
12 Dec 2017   [#8] In reply to [#7]
Hi Michael
I've found a bug.
Step by step :
open MoI v4 beta Dec-11-2017
open Option panel
close it
> crash
I sent you the crash report
12 Dec 2017   [#9]
<<open MoI v4 beta Dec-11-2017
<<open Option panel
<<close it
<<> crash
Not for me :) Windows 10
12 Dec 2017   [#10] In reply to [#8]
Same here on Mac....
But also (sometimes) while changing ShortKeys..
12 Dec 2017   [#11]
Hey Michael, I am having some problems with shortcut keys on the Mac. Fist there are duplicate entries for things like undo (Cmd+Z on the Mac) it also has a Windows entry of Alt+Z. I can't seem to set any shortcuts using Cmd+. I sometimes get a crash when attempting to set shortcuts. Crash report attached.
MoI_2017-12-12-135428.crash
12 Dec 2017   [#12] In reply to [#5]
Hi Ralf,
> this is not working: Box3pts WidthHeight width=2 height=4
It looks like here you are trying to use the new variation of the box 3pt command that I posted yesterday?
The problem here is that the command name for that is Box3ptsWidthHeight, without any spaces in it, you've got a space in the middle of yours above.
12 Dec 2017   [#13] In reply to [#6]
Thanks, I've updated this for the next beta.
12 Dec 2017   [#14] In reply to [#11]
Hi Shane,
Yes, there's still a problem with Alt+ and Cmd+ getting confused with each other. I'll be looking at that for the next beta and I'll be checking out the crash today, thanks.
12 Dec 2017   [#15] In reply to [#1]
re: options dialog crashing on close on Mac, looks like one of the changes for fixing the "mouse moves get ignored in some conditions" are causing that. I'll roll out an updated version soon.
12 Dec 2017   [#16]
Seems a Mac a very sensible machine ? ;)
12 Dec 2017   [#17] In reply to [#16]
Hi Pilou, well this latest crash is from a mistake I made, it happens to be in an area of mouse event handling that is by its nature kind of sensitive.
There are some things that I have found frustrating with the Mac though, like the full screen mode and the "spaces" mechanism is very poorly documented and hard to control.
But I expect things to be reaching a good level of stability soon here.
12 Dec 2017   [#18] In reply to [#8]
Hi Finema & Ralf & shane - re crash on closing options dialog on Mac, I just updated this to a new Dec-12 version which should hopefully fix that, please let me know if you still see it.
Thanks, - Michael
12 Dec 2017   [#19] In reply to [#18]
Thanks for the update, it's OK now.
12 Dec 2017   [#20] In reply to [#19]
That's great Finema, thanks for testing it! There are still some things to fix but hopefully we should be at a pretty stable version now.
13 Dec 2017   [#21]
Does it necessary to reload the PC version ?
13 Dec 2017   [#22] In reply to [#12]
<<<<<The problem here is that the command name for that is Box3ptsWidthHeight, without any spaces in it, you've got a space in the middle of yours above
Yes but i tried different versions with or without space...
Looks like its not implemented right now..
13 Dec 2017   [#23]
Hello Michael,
for me on Win10, F10 Shortcut is not working, in previous beta this was OK.
- Scarab
13 Dec 2017   [#24] In reply to [#21]
No there's no changes for the Windows version.
13 Dec 2017   [#25] In reply to [#22]
Hi Ralf,
Did you install the plug-in into MoI's commands folder?
