Full Version: V4 beta Dec-12-2017 available now
Show messages:  1-4  5-24  25-44  45-64  65-84  85-104  105-124  …  165-176
14 Dec 2017   [#45]
re: Nudge, I'm not sure I understand the problem there, do you guys mean it isn't working at all for you?
14 Dec 2017   [#46] In reply to [#45]
I'm sorry Michael but....What is "Nudge" ?
14 Dec 2017   [#47] In reply to [#46]
Hi Marco, Nudge means "to move by a small amount". It's a command that you can set up so your arrow keys will move objects by a small distance instead of using the mouse. More details here: http://kyticka.webzdarma.cz/3d/moi/#Nudge
14 Dec 2017   [#48] In reply to [#47]
Ah.....OK...now I remember!!
Thanks for reminding me that command :)
Ciao.
15 Dec 2017   [#49] In reply to [#44]
Why not having to separate ini files for V3 and V4 on the Mac?
15 Dec 2017   [#50] In reply to [#49]
Hi Ralf, probably the fix will be to have separate sections inside the ini file, entirely separate ini files shouldn't be necessary.
17 Dec 2017   [#51]
Nudge works fine, but in my humble opinion it's such an essential command that it'd be convenient not having to install it separately.
By the way, a very insignificant observation: if you enter numeric pad "." as a key in the shortcuts, MoI recognizes it as "Numpad," (comma, not period), at least on Mac OS. It does work as numpad period though, so it's just cosmetic.
Regards,
Metin
visualization • illustration • design • 3D (print) models — https://metinseven.com
17 Dec 2017   [#52] In reply to [#51]
Hi Metin, including Nudge by default could have some complications, I'd need to update it in the documentation and also someone following the directions they found for setting up Nudge might follow the instructions to copy it over and then wonder if they should overwrite it. I also don't quite like having too many hidden commands by default.
At some point I'd like to solve these problems in a more comprehensive way by having some kind of script browser that would let you specify which scripts you wanted to install from some central repository and keep them installed between versions so you wouldn't need to copy things around manually. But I'm not sure when that will happen. Maybe I can do it in a few stages though and have the "keep installed" part working before doing the full browser implementation.
re: numpad comma - that's not happening for me over here, it might be a bug in the Qt keyboard mapping which could be difficult to fix.
What happens if you actually type that numpad key in a text editor, do you get a comma or a period?
17 Dec 2017   [#53] In reply to [#52]
Hello Michael,
short status for linux platform/wine(OpenSuse Leap 42.1): Everything seems to work. Display performance while extruding or selection is slower than V3.
Have a nice day
Karsten
17 Dec 2017   [#54] In reply to [#53]
Hi Karsten, thanks for testing it on Linux. What video driver and version of wine are you using?
Extruding is probably a timing problem related to the extruded result getting continuously canceled when you move the mouse, it's on my list to investigate.
Selection might be harder to do anything about if its just texture readback to the CPU that's slow.
Do you notice anything that looks like a sort of delayed reaction like the display is lagging one frame behind what is supposed to be shown?
18 Dec 2017   [#55] In reply to [#52]
Some sort of commands manager is a great idea. Maybe you can combine it with a manager for the hidden settings in MoI.ini, such as the triangulation methods (or you could add those settings to the preferences dialog).
I've tried the numpad period key in a text editor, and indeed, it generates a comma by default. I had never noticed that before, because I only use it for shortcuts. If it doesn't happen on your Mac system, then I suspect it's due to the Dutch language setting. Over here in the Netherlands we separate decimals by a comma in stead of a period.
18 Dec 2017   [#56] In reply to [#55]
Hi Metin,
Thanks for testing it! Yes, I think you're right that it has to do with having Dutch set as the operating system language setting.
So your numpad period key showing up as Numpad comma is something that's just built into the operating system keyboard handling, I don't think there is anything that I'd do to change that in MoI. There is probably some way to edit a key mapping table for the OS that could change it though.
18 Dec 2017   [#57] In reply to [#54]
Hello Michael,
I'm using wine 1.82 and a proprietary AMD Graphic driver (Radeon HD 6320). It's outdated hardware, but it's only a comparison between v3 and V4 Beta. Another problem I found, is the naming of an object - result is a crash MoI bug report (unhandled exception).
Have a nice day
Karsten
moi_report5.zip
18 Dec 2017   [#58] In reply to [#57]
Hi Karsten, thanks for sending the crash report. The naming crash in Wine looks like a Wine bug. MoI does happen to throw an exception when it checks to see if the name dialog gave back a value of -1 meaning cancel, but that exception is caught and ignored. But on your Wine build it's not being ignored so either the SEH exception handling is not working properly or maybe there's a setting for reporting "first chance" exceptions that needs to be turned off so that exceptions that are caught by the app don't register as a crash.
I"ll modify this for the next build though so no exception will be thrown when modal dialogs are closed.
19 Dec 2017   [#59]
Hi Michael.
Another line in the error list.
Vladimir.
19 Dec 2017   [#60] In reply to [#59]
Hi Vladimir, it looks like the bug is that in V4 the construction line finishes when you release the mouse outside a viewport unlike V3, is that correct?
19 Dec 2017   [#61] In reply to [#60]
Yes, when you release the button, the connection is lost.
19 Dec 2017   [#62]
Hi
I can't reproduce it on mac
19 Dec 2017   [#63] In reply to [#62]
Hi Finema.
This is in Windows 7.
19 Dec 2017   [#64] In reply to [#63]
OK Vladimir
