14-33
34-53
54-73
74-93
94-113
174-176
Hi Metin, thanks for testing it - sounds good so far!
The command "Print3D.js" is not included in the new beta(?)
Please consider adding "Nudge.js" to the "stock" commands(?)
General Windows 7 observation, nothing to do with MoIBeta: When windows explorer is "docked" to half screen view,
and when preview is active, trying to highlight, copy or paste should not be done in the preview area, IMHO.
Thanks Michael,
my mistake. You are right. Now F10 function is working for me.
Many thanks, by the way this is Super suport and very nice community.
- scarab
Yeah I removed it since it didn't do anything. At one point in the past it was going to be for integrating with a separate program called Print3D which does not exist anymore.
Adding Nudge to the commands that ship with MoI would be great indeed. I couldn't live without it.
Hi Metin.
What is "Nudge" ?
I admit my ignorance about that...
Hi Michael, I am no longer getting a crash we editing the shortcut keys but my changes are not being saved. I can change them and they will work until I close and re-start then the changes are lost. Manually editing the ini. won't work as my changes don't seem to "stick" there either.
Hi Shane,
this is because the backward compatibility to the Moi3 for Mac under wine - even the "winewindows" doesnt know about the "command" key and therefor moi translates them to Alt keys automaticly.
For me this backward compatibility is not necessary because i dont use v3 any more.
Hi Metin,
I agree Nudge is a necessity.....
James Elliott
Hi shane yes there's a problem like Ralf describes with Cmd key shortcuts getting lost if you open V3, that's on my list to work on for the next release.
re: Nudge, I'm not sure I understand the problem there, do you guys mean it isn't working at all for you?
I'm sorry Michael but....What is "Nudge" ?
Hi Marco, Nudge means "to move by a small amount". It's a command that you can set up so your arrow keys will move objects by a small distance instead of using the mouse. More details here:
http://kyticka.webzdarma.cz/3d/moi/#Nudge
Ah.....OK...now I remember!!
Thanks for reminding me that command :)
Ciao.
Why not having to separate ini files for V3 and V4 on the Mac?
Hi Ralf, probably the fix will be to have separate sections inside the ini file, entirely separate ini files shouldn't be necessary.
Nudge works fine, but in my humble opinion it's such an essential command that it'd be convenient not having to install it separately.
By the way, a very insignificant observation: if you enter numeric pad "." as a key in the shortcuts, MoI recognizes it as "Numpad," (comma, not period), at least on Mac OS. It does work as numpad period though, so it's just cosmetic.
Regards,
Metin
visualization • illustration • design • 3D (print) models —
https://metinseven.com
Hi Metin, including Nudge by default could have some complications, I'd need to update it in the documentation and also someone following the directions they found for setting up Nudge might follow the instructions to copy it over and then wonder if they should overwrite it. I also don't quite like having too many hidden commands by default.
At some point I'd like to solve these problems in a more comprehensive way by having some kind of script browser that would let you specify which scripts you wanted to install from some central repository and keep them installed between versions so you wouldn't need to copy things around manually. But I'm not sure when that will happen. Maybe I can do it in a few stages though and have the "keep installed" part working before doing the full browser implementation.
re: numpad comma - that's not happening for me over here, it might be a bug in the Qt keyboard mapping which could be difficult to fix.
What happens if you actually type that numpad key in a text editor, do you get a comma or a period?
Hello Michael,
short status for linux platform/wine(OpenSuse Leap 42.1): Everything seems to work. Display performance while extruding or selection is slower than V3.
Have a nice day
Karsten
14-33
34-53
54-73
74-93
94-113
174-176
