11-30
31-50
51-64
The "Nudge" shortcut key scripts do not seem to be working. (?)
EDIT: correction, Nudge works fine, if the .js is in the command directory.
It seems to be working ok for me over here. There are a few different versions of Nudge though, can you please post the one you're using that doesn't work, and also your shortcut keys setup for calling it?
The error is mine :-)
I did NOT copy the Nudge.js file over to MoI4beta. I guess that Nudge is not a standard MoI command...
I did copy _Nudge.js over, which is a waste of a line in Max's customUI, given that my shortcut keys are for example,
Key: DownArrow command:Nudge Down
Key: LeftArrow command:Nudge Left
Key: PageDown
(Well part of this post disappeared.)
Nudge works fine.
My install method, at the office anyway, was faulty.
I need to check for other missing non _ scripts.
here is a video showing what I was talking about, I'm using win10. I can't get the the text area to respond when I am exporting.
cheers,
Val
I finally figured it out. A person has to hit "enter" inside the text box to get it to respond. I was hitting "enter " ouside of the box and it would export Funny how one does something everyday and then suddenly can't work out the simplist thing.
Hi Val, thanks - yeah I can repeat the "text field requires enter" problem over here too. I'll be working on that in the next couple of days to fix it for the next beta.
If I'm not mistaken, with QT (at least previous versions), you can set the stack size of an individual thread. The default it's set to the same size as the main thread. I don't know if you're architecture is such that controlling the thread size in a process would help.
Dose anyone know how to get the Custom UI working in V4 BETTA?
Hi scott - it's not stack size that I was looking to set, it's a limit on the total amount of committed virtual memory pages for the entire process. There does not seem to be any mechanism on Mac to set this particular kind of limit. The UNIX function to do it, setrlimit, does not do anything for certain areas that are handled by the Mach part of the kernel instead of the BSD part of it, see here:
https://lists.apple.com/archives/unix-porting/2005/Jun/msg00115.html and note that RLIMIT_DATA is not enforced.
But it's not really a big problem though, it's not something that you should need to mess with normally.
Hi ogarogar,
I think Max has said that he's planning on making an updated version of it.
For Windows7:
With the exception of object library, the customui works pretty good in V4Beta, with maximized MoI window.
64 bit MoI4beta located at c:\program files\yourMoi4betaDirectoryName (\ui).
In the MoI4 ui folder, the Command bar must be modified a little bit, as previously described in November posts.
http://moi3d.com/forum/index.php?webtag=MOI&msg=8675.40
Copy over the customUI for MoI3, to ui folder, and scripts with a _ prefix to MoI's commands folder.
I think that will do it... (?)
Disclaimer, use at your own risk, and make backups...IMHO it is not particularly dangerous.
Or wait for Max's upgrades...
Edit, deleted last paragraph.
Hi All,
I am new here, so hello to everybody. After testing Moi V3 I have already bought it. It is great, thanks Michael. Could you check in this V4 beta, that you are able to change Grid - Style of lines? I have Win 10 version and change of Style from Solid to others don't make any effect. I am sorry for my language, it is not my mother's one.
Hi Spunar,
On Win7, Grid seems to work fine, re styles/colors, etc.
Hi scarab, dashed/dotted line styles are not implemented in v4 quite yet. They won't be in the next beta but probably the one after that.
OK. Understand. Many thanks for feedback.
- scarab
11-30
31-50
51-64
