Full Version: V4 beta Nov-27-2017 available now
Show messages:  1-19  20-39  40-59  60-64
29 Nov 2017   [#20] In reply to [#9]
Thanks for the clarification of the Area zoom, makes sense.
A little reminder, although it's probably already on your to-do list: switching to full-screen mode on MacOS doesn't yet work using the system shortcuts — Control + Command + F to toggle full screen mode, or Esc key to exit full screen mode.
Having said this, I'd very much prefer Esc to solely remain a MoI function to cancel operations in stead of also exiting full screen mode. In ZBrush, pressing Esc to cancel an operation also exits full screen mode, and even exits ZBrush Edit mode at the same time, which is quite frustrating.
Command + M to minimize an application to the dock, and Command + H to hide an application both work fine with MoI.
Metin
visualization • illustration • animation • 3D (print) design — https://metinseven.com
29 Nov 2017   [#21] In reply to [#15]
Hi Moujiik, it looks like if you double-click on a field things will be messed up after that and you have to push Enter for the field to accept the change (which will also close the dialog). That seems to reliably reproduce it.
29 Nov 2017   [#22]
Hi Michael.
One more trouble. Buttons box.
To watch the video.
29 Nov 2017   [#23] In reply to [#22]
Hi Vladimir, thanks for posting that video, I can reproduce that here. It will happen if you generate a degenerate rectangle for the base of the box. MoI v3 would just exit the command in that case and I will tune up V4 to behave the same instead of generating a script error.
29 Nov 2017   [#24] In reply to [#21]
I also repeated this.
29 Nov 2017   [#25]
setCameraAndTarget()
does not work in V4 but in V3.
This script should set the cam to point 50,50,50 and the target to point 0,0,0
script: camPt=moi.VectorMath.createPoint(50,50,50);targetPt=moi.VectorMath.createPoint(0,0,0);moi.ui.getActiveViewport().reset();moi.ui.getActiveViewport().setCameraAndTarget(camPt,targetPt);
(copy script, in moi hit tab and paste, hit enter)
Ralf
29 Nov 2017   [#26] In reply to [#1]
Have you thought about some kind of setting for MoI regarding available RAM to the app as a user setting?
So now with 64 bit, if i crank some model meshing parameters, MoI can quickly gobble up all my RAM.
With tge 32 bit version, i could max out MoI and the worst would be i lock up MoI abd have to force quit it...
With the new 64 bit version, i can lock up the entire system and it can be problematic.
So if i know i have 16 or 32 gigs of RAM, i could set MoI to know to use 12 or 30 gigs, type of thing....
29 Nov 2017   [#27] In reply to [#25]
Hi Ralf, re: setCameraAndTarget() in v4 , thanks for reporting this bug I've got it fixed up for the next beta.
29 Nov 2017   [#28] In reply to [#26]
Hi Burr,
I had not really thought about that, but it should not be too hard to add a moi.ini setting for that. Something like:
[Settings]
MaxProcessMemoryUseGB=12
29 Nov 2017   [#29] In reply to [#28]
That would probably be a good setting to have....
Thanks again!
29 Nov 2017   [#30] In reply to [#29]
Hi Burr, that memory limit setting will be in the next beta. It will be for Windows only though, I can't seem to find a way to do it on Mac.
30 Nov 2017   [#31] In reply to [#30]
So righteous! Thanks!
30 Nov 2017   [#32]
Hi Michael.
1 Dec 2017   [#33] In reply to [#32]
Hi Vladimir, thanks for reporting these bugs.
I can repeat the command button staying stuck on, I should be able to fix that for the next beta.
I can't repeat the Text one though, so the problem is that you get 0 by default for those 2 values? EDIT: it was a locale dependent bug that's why it wasn't happening here.
Thanks, - Michael
1 Dec 2017   [#34] In reply to [#32]
Hi Vladimir, ok I see why I can't repeat the text one, it's because it was a locale dependent bug. This should be fixed now for the next beta, thanks!
1 Dec 2017   [#35] In reply to [#33]
Hi Michael. I'm late with the answer and still answer. This error arises from the first beta. If you remember I wrote to you about the script Rebuild so Maksim Smirnov checked it on Mac and Windows and it manifests itself only in Windows.
Vladimir.
1 Dec 2017   [#36] In reply to [#35]
Thanks Vladimir, now I finally understand about the Rebuild problem too - yes it's this same issue. Since the bug was triggered only if your operating system locale uses commas for the decimal separator it wasn't happening here and I thought you were talking about a different thing then.
It will be fixed for the next beta and should fix the default values for both Rebuild and Text commands and possibly others.
1 Dec 2017   [#37]
I've try to import a Stp-file from Solid Works to Moi, but it's dosn't work.
The import process is stopped without a message and i get an empty scene.
The file is 192mb big. I try the newest build from Moi 4.0 beta Nov 27.
smaller files are imported witout problems.
The import to Rhino works fine.
Best regards
Jörg
1 Dec 2017   [#38] In reply to [#30]
Conrcerning the memory limit on Mac, there might be a hint there :
https://stackoverflow.com/questions/12268925/limit-memory-allocation-to-a-process-in-mac-os-x-10-8
It's the "Answer" comment
Marc
1 Dec 2017   [#39] In reply to [#20]
Hi Michael
Have you any idea how i can bypass my virus scanning to enable me to install v4.0 beta?
Avast says its a virus and will get back to me
JO
