134-153
154-173
174-193
194-213
214-231
Hi JP, well that's pretty mysterious to me - over here I have tried using Cmd+H to hide it, then clicking on the dock icon to restore it and I can draw and click on things immediately after that. Tomorrow I'll try updating from 10.13.0 to 10.13.1 and see if that makes any difference.
Are you possibly running any utility or helper type programs that involve window handling?
Micael
"Are you possibly running any utility or helper type programs that involve window handling?"
what do you mean ?
On Windows 7, with regular Logitech mouse, following JP's lead, there is a problem with using the Lightbulb icon in my taskbar.
Click lightbulb to open MoI v4, MoI works normally, draw a circle, square, etc.
Click lightbulb to "hide" v4.
Click lightbulb to "unhide" v4.
The dialog window in the upper righthand corner no longer functions. It is blank, or frozen depending upon state before hide/unhide.
Drawing tools do not work, unless I right click on the mouse.
Then a drawing tool can be clicked on, say circle, but menu expansion does not show, but the circle, can be drawn.
Unless a right click is done, another drawing tool cannot be selected, also if two drawing tools are selected, then right click is done,
the first one can be drawn.
There are some permutations. If a drawing tool was started before the hide/unhide occurs, it will work after unhide, but the dialog screen is frozen.
Sometimes planar works, or not.
Using the __ button in the upper right hand window has similar effect to clicking lightbulb in taskbar.
Using the change window size button (the overlapping squares in upper right hand corner of window,)
(Sometimes) RESTORES functioning.
(Sorry I do not know the names of all of the buttons or regions.)
yes it's exactly what it's happen for me.
Please try :
1•Click lightbulb to open MoI v4, MoI works normally, draw a circle, square, etc.
2•Click lightbulb to "hide" v4.
3•Click lightbulb to "unhide" v4.
4•CLIC AGAIN ON LIGHTBULB and try to draw
thanks
One more clue:
If I start from a NON-maximized MoI window, there is no problem.
(as far as I have minimally tested.)
- B
Yes ! well done Brian
If i reduce the window there is no problem indeed.
Another very minor topic:
In v3, when I close a script, then do a right click, the script will repeat, using previously altered options from the dialog region, upper right corner.
In v4, after a script is closed, right click repeats the script, using original options.
Maybe a minor .ini setting?
EDIT, I may be PARTLY wrong in the above statements :-) (I'll do some more testing.)
ps, got a grid of Truchet tiles to work. (Script still needs some work.)
v4 is near instantaneous.
v3 is quite slow, due to .js as previously explained by MG.
Brian,
i've tested with DistortCurves script and options changed are here
Yes, now I am able to duplicate this 'freeze' problem.
Open MoI 4
Hide it using the - key in the upper right corner of the screen.
Open another program ... shut it down.
Bring MoI back to full screen by clicking on the MoI icon.
Commands are frozen.
Reduce MoI to part screen. Open it to full screen again.
Now it works.
For me this is intermittent. It does not happen each time I follow the same routine.
cheers,
eric
Hi Finema,
I've edited my "repeating scripts vs options" post, as being partly wrong. :-)- Brian.
But partly right.
Using LineWeb as an example, MoI3 preserves Build options upon exit of command and right click.
MoI4 does not preserve Build options upon exit of command, and subsequent right click repeat of command, but does preserve closed checkbox.
Running the latest v4 Beta Mac Version (on El Capitan, 10.11.6) when I create second window a new moi3d app is launched, Just checking this is not the expected behaviour ?
But the app is looking great on a retina Mac laptop.
Colin
Seems a replicate variation of my freezing Moi / Forum / Moi! ;)
So I am not alone in the space! :D
http://moi3d.com/forum/index.php?webtag=MOI&msg=8675.103
Hi Michael and everyone.
I can confirm the same issue raised by Finema :
I use Windows 10 Pro 64 Bit.
I can also confirm finerma
dialog locks up after hiding/unhiding v4
I also use win 10 pro 64 bit
thanks,
Val
All right, well that gives me some more things to try, and it's also interesting that the hide/show problem is cross platform as well.
Hi Colin,
Yeah unfortunately this is going to be the way that I have to make it work. MoI expects that each main program window has its own thread and process but there isn't any way on Mac for multiple processes to share a single dock icon.
The way that Apple has implemented multiple windows in its standard application infrastructure is problematic because they have them all inside the same process and sharing a single UI thread which means they can interfere with each other in various ways. If one crashes for example they all crash because they aren't running in separate processes.
So this (multiple app windows) is an area where the standard Apple way is just not good and I don't expect to have MoI follow the standard behavior for this particular thing.
I think someone mentioned this.
'Snaps' have stopped working for me ... and this seems to have migrated to V3.
mid, int, end etc have stopped working.
Windows 10 ..
eric
Hi eric, are they all enabled on the menu? :
And object snap turned on (highlighted in orange on the main button) ?
Ok, I've finally been able to reproduce the UI freezing problem over here, seems to be easier to reproduce on Windows. When it happens it looks like clicks still do stuff but nothing visually updates. I'll be digging into it.
134-153
154-173
174-193
194-213
214-231
