Full Version: V4 beta Nov-13-2017 available now
Show messages:  1-5  …  86-105  106-125  126-145  146-165  166-185  186-205  206-225  226-231
15 Nov 2017   [#146] In reply to [#138]
Hi Finema,
the CustromUI runs so far and reacts as desired.
Unfortunately, however, no thumbnails are shown in the Obj Library.
Clicking on the saved. 3DM files does not load the models and new models cannot be saved.
The Ext Scripts window will open as expected - but some scripts won't run at all or abort with an error message.
The Snapshot function works like it should.
-moritz
Bildschirmfoto 2017-11-15 um 13.58.19.png  Bildschirmfoto 2017-11-15 um 14.16.55.png
15 Nov 2017   [#147] In reply to [#146]
Hi Moritz
I only use Extscript, it's because i don't notice thumbnails error.
We are waiting for Max CustomUI update.
15 Nov 2017   [#148] In reply to [#147]
To me the beta does not work :(
Message 8675.149 was deleted
15 Nov 2017   [#150]
nice.
how much will be an upgrade from v3?
15 Nov 2017   [#151]
Thanks Michael G.!
Just curious, what do the numbers under the view name represent?
15 Nov 2017   [#152] In reply to [#151]
quote:
The number up there is the amount of time in milliseconds it took for the last screen draw in that viewport. That will be up there for a while so it will be a little easier to measure display performance as more work is done in that area.
15 Nov 2017   [#153] In reply to [#152]
15 Nov 2017   [#154] In reply to [#148]
Hi Tony,
Can you please e-mail me the crash dump file, it looks like it was created at c:\Users\Antonio\AppData\Local\Temp\moi_report5.zip - there may be several there all named moi_report1.zip, moi_report2.zip , etc...
If you can e-mail those to me at moi@moi3d.com that give some information on what might be going wrong.
15 Nov 2017   [#155]
Hi VKNW123, I was just replying to your message about SelectByType not working - I guess you probably already found that it was a plug-in that you installed in V3 and so you need to also install it in V4 by copying it into the V4 commands directory.
15 Nov 2017   [#156] In reply to [#150]
Hi glmr,
Currently it's planned to be the same as the V2 to V3 upgrade which is $100 USD.
15 Nov 2017   [#157] In reply to [#1]
Hi Michael.
It's a miracle!! :)
The mysteries of life...
After only less than 3 days from the first V4 beta of Moi.....ta-ta!!! McNeil announces the final Beta Stage for Rhino V6 !!!!
What a timing :)
Another great "side effect" caused by Moi!!!
LOL :)
15 Nov 2017   [#158]
I noticed that it was more fluid to create solids (sphere, box, plane) on the V3. There is a slight dead time between the first click and the second click on V4.
Also sometimes it is impossible to create the shape after the first click. Pick panel fields stay empty. (it happens randomly)
15 Nov 2017   [#159] In reply to [#158]
Hi Finema, I can't seem to detect any sphere lag over here. I wonder if that and the other thing are related. What OS and type of mouse device do you use?
Can you describe the pick panel fields empty thing in a bit more detail, do you mean you start the sphere command and nothing at all shows for sphere in the upper right area of the window, does it just not change at all? Or something like it shows the first prompt but not the second prompt?
I wonder if it's getting stuck in something like a drag/drop.
Thanks - Michael
16 Nov 2017   [#160] In reply to [#159]
my OS : Mac OS 10.13.1
mouse device : Magic Mouse 2
It happens sometines (randomly), when i want to create a sphere, plan, box, rect, etc..
Choose a tool
First Clic > Pick corner point panel appears
and after, drag/drop have no effect and Pick other corner panel (second prompt) stay empty and block.
16 Nov 2017   [#161] In reply to [#160]
Hi Finema, do you possibly have any other mouse you could use to test with to see if it only happens with the magic mouse?
16 Nov 2017   [#162] In reply to [#160]
Hi Michael ..
I may be experiencing something similar. Sometimes the UI icons don't seem to respond at all. It is random but once it is locked up it seems difficult to get a response. I'll start paying specific attention to see if I can describe when it happens.
Windows 10 Pro. HP mid tower, Intel 7, 16g ram.
eric
16 Nov 2017   [#163] In reply to [#161]
Michael,
I use a magic Mouse 2.
But i've tested with a Magic Mouse (1) and i can't reproduce the bug.
16 Nov 2017   [#164] In reply to [#163]
Can you zoom with your MagicMouse2?
I can only pan...
But your bug doesnt happen to me..
Ralf
16 Nov 2017   [#165] In reply to [#164]
Hi Ralf
No, I can't zoom with magiMouse2
