 81-100
 101-120
 121-140
 141-160
 161-180
 181-200
 201-220
 221-231
Hi Marco,
> Good. I understand your point of view.
> A "no regression" it's kinda like a "foundation" :)
Yup, that's it exactly.
Hi Max,
> I really miss the snap names when snapping (Mid, End, Int etc..)
> Is there a way to get them back?
They'll definitely be coming back but I still have some work to do for implementing them. It's one of just a couple still unfinished areas, it's not that they're just disabled by a setting or something like that. May be something like a couple more weeks before having these last pieces working again.
Thanks!
Thank you Michael.
I'll wait for Max's update.  (The customui is working well in MoI4, as far as I can tell.)  But meanwhile, I'll do some more
testing of my file copying (perceived) problem/confusion, with some more elaborate test names for *.js.  (I'm using notepad++.)
(I've got 391 windows fonts installed, but do not see Open Sans.)
Hi Finema, thank you, but I'm on Windows7, customui is working, but I seem to have a problem with script file copying(?).
I noticed that it was more fluid to create solids (sphere, box, plane) on the V3. There is a slight dead time between the first click and the second click on V4.
Also sometimes it is impossible to create the shape after the first click. Pick panel fields stay empty. (it happens randomly)
Hi Finema,
the CustromUI runs so far and reacts as desired.
Unfortunately, however, no thumbnails are shown in the Obj Library.
Clicking on the saved. 3DM files does not load the models and new models cannot be saved.
The Ext Scripts window will open as expected - but some scripts won't run at all or abort with an error message.
The Snapshot function works like it should.
-moritz
Hi Moritz
I only use Extscript, it's because i don't notice thumbnails error.
We are waiting for Max CustomUI update.
To me the beta does not work :(
Message 8675.149 was deleted
nice.
how much will be an upgrade from v3?
Thanks Michael G.!
Just curious, what do the numbers under the view name represent?
quote:
The number up there is the amount of time in milliseconds it took for the last screen draw in that viewport. That will be up there for a while so it will be a little easier to measure display performance as more work is done in that area.
Thanks.
Hi Tony,
Can you please e-mail me the crash dump file, it looks like it was created at c:\Users\Antonio\AppData\Local\Temp\moi_report5.zip - there may be several there all named moi_report1.zip, moi_report2.zip , etc...
If you can e-mail those to me at
moi@moi3d.com that give some information on what might be going wrong.
Hi VKNW123, I was just replying to your message about SelectByType not working - I guess you probably already found that it was a plug-in that you installed in V3 and so you need to also install it in V4 by copying it into the V4 commands directory.
Hi glmr,
Currently it's planned to be the same as the V2 to V3 upgrade which is $100 USD.
Hi Michael.
It's a miracle!! :)
The mysteries of life...
After only less than 3 days from the first V4 beta of Moi.....ta-ta!!! McNeil announces the final Beta Stage for Rhino V6 !!!!
What a timing :)
Another great "side effect" caused by Moi!!!
LOL :)
Hi Finema, I can't seem to detect any sphere lag over here. I wonder if that and the other thing are related. What OS and type of mouse device do you use?
Can you describe the pick panel fields empty thing in a bit more detail, do you mean you start the sphere command and nothing at all shows for sphere in the upper right area of the window, does it just not change at all? Or something like it shows the first prompt but not the second prompt?
I wonder if it's getting stuck in something like a drag/drop.
Thanks  - Michael
my OS : Mac OS 10.13.1
mouse device : Magic Mouse 2
It happens sometines (randomly), when i want to create a sphere, plan, box, rect, etc..
Choose a tool
First Clic > Pick corner point  panel appears
and after, drag/drop have no effect and Pick other corner panel (second prompt) stay empty and block.
 81-100
 101-120
 121-140
 141-160
 161-180
 181-200
 201-220
 221-231
