 10-29
 30-49
 50-69
 70-89
 230-231
ok
an other thing
Sometimes i can't draw any curves or solid on scene.
See my screenshot, the panel on the right stay empty and it's impossible to drax something
<< also linked to from the download page on the main web site.
Don't see any link of that! ;)
Hi Michael
Thanks a lot.
The UI working more or less properly on Retina.
Drawing seems to work well.
There is a problem with all operations (fillet, chamber, boolean, ofset etc.)
Cheers Stefan
Michael, congratulations on launch! Exciting stuff. A quick 10 minute pass (no custom ini, just playing) and it all looks GREAT! Looking forward to spending more time playing soon :-)
> << also linked to from the download page on the main web site.>
It seems to be there ok... Maybe hit reload on your web browser?
Yep : reload was the trick! Sorry for the disturb! :)
Hi Michael!
Thanks a lot for your efforts !!!
This is a brief report :
My laptop config is :
Windows 10 Pro 64 Bit English
i7-4790K 4.0 - 4.4 Ghz
32 Gb Ram 1600 DDR3
Nvidia Quadro K3100M 4Gb 768 Cuda Cores (Driver Version 385.69)
SSD Samsung 512 GB
1) Just downloaded and installed. No problem at all :)
2) All V3 shortcut keys works properly with the V4!! Thanks!
3) I spent few minutes playing with the new V4.
I downloaded some 3dm files.
4) Loading is OK
5) To stress CPU/GPU I'm using a 5 degrees mesh angle
6) I recorded this video to show you V4 running on my laptop.
I noticed these things :
A) It seems that there is no speed gain compared to V3, both in terms of loading and in terms of navigating the viewports (:
B) It seems that V4 has the same issue of displaying "fake edges" in some part of the models
C) As you can see in my video, the antialiasing of edges and above all of surfaces's boundaries is unsatisfactory.
I didn't touch anything in my Nvidia Control Panel.
I'm using V4 as is.
This is the video :
http://take.ms/ywed7
7) I have also copied all my custom commands/scripts to the new V4.
In next days I will let you know what works and not works correctly.
Thanks a lot again.
I stay tuned.
Ciao.
p.s.
My laptop has a simple Full HD (1920x1080) panel.
Just some example screenshots :
Ciao!
Hi Marco, thanks for testing it!
That's expected right now and it's good in fact that there isn't any regression. I haven't had a chance yet to finish the work on speed improvements by making use of lots of available VRAM, there is some of the infrastructure in place for it but that's something that I will be working on more once things stabilize. Please remember this is only the first beta and does not contain everything that I want to have in the final v4 release in it as of yet.
That's expected, it should behave exactly the same as V3 right now.
Same thing here, it's expected to behave the same as MoI v3 at this moment. But it will not be difficult for me to add in an option to enable MSAA once the initial stabilization is done.
Thanks,  - Michael
Ok Michael!
@You : "...Please remember this is only the first beta and does not contain everything that I want to have in the final v4 release in it as of yet..."
Got it! :)
I stay tuned.
I will let you know my next test results ASAP (I think only late at night...)
Ciao!
Here the FrenchStrings.txt updated! ;)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/frenchstrings.txt
just a little thing : seems there is no more "line break" when edit with the normal Windows NotPad !
works fine with NodePad ++
Firstly, thanks for the V4beta! I look forward to big things
with my favourite app.
As already established, most tools don't work on a mac,
but I wanted to test custom UI and node editor.
As you can see both run with the beta, but this error
occurs when pinching on trackpad in NE.
Also some navbar buttons have disappeared.
Hope this helps
Also, when I install Custom UI, I lost icons on the footer (File, Save, Undo, etc...) . (as we see in James screenshot)
Hi Finema, for lost icons with CustomUI, that's because installing CustomUI writes a MoI v3 version of CommandBar.htm in place of the V4 one which is slightly different. So you can't install it by copying the CommandBar.htm directly like you did with v3, either you've got to splice the extra stuff into the new CommandBar.htm or wait for a v4 version of CustomUI.
In general since the UI is slightly different from v3 you can't just copy entire v3 customized UI files into v4, you've got to merge changes in with the new v4 structure.
More info on CustomUI missing icons - the missing ones are the ones that used the
res:// protocol for getting the icon from moi_lib.dll binary resources. MoI v4 doesn't have any of those anymore and doesn't have a
res:// protocol handler anymore so that's why those are missing. You'll need to splice in the v4 buttons for those ones instead of using the v3 buttons.
Hello,
Congrats Michael! What a milestone! Big day for you and Moi3D users. Thanks a lot for your effort.
I have 2 questions:
1. v4 will live side by sie with v3, or will replace it?
2. There is any kind of migration soft for scripts? I believe v3 had some sort of batch copying scripts (and/or short keys)?
Carlos
Hi Carlos, thanks! V4 can be used side-by-side with V3 and in fact I'd recommend having them both especially at the moment while there are rough edges being worked out. But it is my goal to stabilize v4 rapidly and get it to full parity with v3.
For migration it's just any custom scripts that you will need to copy over from the v3 commands folder into the v4 commands folder. You can copy the contents of the entire folder over and just say no to overwriting. Shortcut key definitions will come over automatically since they're stored in moi.ini and v3 and v4 will use the same moi.ini file.
Ok, so for the Mac version I'm getting close to solving it, I didn't catch it because it only gets messed up when packaging it up for deployment. The way library loading is organized on the Mac is pretty different from what I'm used to. Just part of the brave new world of a native Mac build...
OK Michael !
I'll wait for the custom Ui v4.
In fact I just want a button in the interface with which I can run extra scripts. (it's OK, i've just add a line code in CommandBar.htm V4)
I love the new clean interface of V4 on my Imac retina !
Hello,
Thanks Michael for this 64bit flavor !
I did a couple of test to push the mesher :
Engine V-Twin, by Aled J Taylor : +- 23M Ngones !!!
[LINK]https://grabcad.com/library/engine-v-twin-4-valve-heads-1[/LINK]
LAMBORGHINI AVENTADOR, by Fateh MERRAD : +-8M Ngones
[LINK]https://grabcad.com/library/lamborghini-aventador-lp700-1[/LINK]
 10-29
 30-49
 50-69
 70-89
 230-231
