Full Version: Lots of unkown
Show messages:  1-6  7-26  27-46  47-66  67-86  87-106  107-126  …  367-372
27 Feb 2018   [#47] In reply to [#46]
i try to avoid extra enter keystroke
since all my keyboard is almost to the r,f,v maximum
one more idea to look at..
option for 1 edge fillet, chamfer or other heavy calculation - to have a fast look of final result
25 Mar 2018   [#48]
fun with moi
26 Mar 2018   [#49] In reply to [#48]
Very nice!!
26 Mar 2018   [#50]
if smb have free time i have a request for scripting
perspective camera from image
26 Mar 2018   [#51] In reply to [#50]
Hi Cemortan_Tudor, that would probably be a pretty time consuming script to create, so it's probably not too likely to happen.
I'd recommend using already existing methods with other software, for example SketchUp:
https://help.sketchup.com/en/article/3000115
or Blender with BLAM:
https://blender.stackexchange.com/questions/33625/still-frame-camera-solve/33628
or here is a more manual method:
https://www.fxphd.com/tips/finding-the-cameras-position-tutorial/
or another method using Blender again:
http://www.chocofur.com/camera-matching-tutorial-in-blender.html
26 May 2020   [#52]
easy script, remade from hide curve, toggle shaded mode (working with reference images)
script:var breps = moi.geometryDatabase.getObjects().getBReps(); var hide = true; for ( var i = 0; i < breps.length; ++i ) { var faces = breps.item(i).getFaces(); if ( i == 0 ) hide = !faces.item(0).hidden; faces.setProperty( 'hidden', hide ); }
26 May 2020   [#53] In reply to [#52]
In French ;)
script:/* Bascule Mode Filaire Ombré en Mode Image */var breps = moi.geometryDatabase.getObjects().getBReps(); var hide = true; for ( var i = 0; i < breps.length; ++i ) { var faces = breps.item(i).getFaces(); if ( i == 0 ) hide = !faces.item(0).hidden; faces.setProperty( 'hidden', hide ); }
https://moiscript.weebly.com/filaire-ombreacute.html
PS : seems it's working in any mode ! (?)
27 May 2020   [#54]
yes, i was searching on google, then on http://kyticka.webzdarma.cz/3d/moi/, havent found, made myself
thanks for new resource
27 May 2020   [#55]
Add English documentation prefix?
script: /*!Toggle shaded mode */ var breps =
28 May 2020   [#56]
Clearing Ai exports with dynamic sketch - works perfectly - visual export bugs
28 May 2020   [#57] In reply to [#56]
Hi Cemortan_Tudor, you might be able to reduce those by using a larger "Canvas megapixel resolution" value in the AI export options dialog. Maybe try doubling it and see if that helps. If you set it too high it can consume a lot of memory though.
28 May 2020   [#58]
amazing stuff ))
from 1gb ram up to 4gb, resolution 25 -> 100, almost no rework needed
30 May 2020   [#59]
one more thing discovered, ai -> copy to clipboard - paste in moi works without any extra files, reversed doesn't work (
30 May 2020   [#60] In reply to [#59]
hi,
there is a script for that:
script: /*! Copy AI format to clipboard */ moi.geometryDatabase.copyToClipboardAI();
30 May 2020   [#61] In reply to [#60]
thanks !!
30 May 2020   [#62] In reply to [#59]
The clipboard copy to PDF or AI needs to be triggered by a separate shortcut like that because it has options UI for it. When you do the regular copy to clipboard, MoI does not know at that time where you're trying to target and it would be weird to pop up the AI options dialog for every Ctrl+C copy.
4 Jun 2020   [#63]
shell, mb u'll need
5 Jun 2020   [#64]
script:/* grid toggle */moi.drawingAids.gridSnap = !moi.drawingAids.gridSnap;
5 Jun 2020   [#65]
i'm using trim -> trim points a lot
reworked the script so when i'm pressing second time t ('t' is my trim hotkey) fires event 'add trim point' - no second hotkey for that
earlier i was using -> script: /* Trigger Add trim points in Trim command */ moi.ui.fireUIEvent( 'addtrimpoints' );
idk how moi.command.registerCommandSpecificShortcutKey works (what registers ! only strings ?)
Trim.js
5 Jun 2020   [#66]
network profiles
