Full Version: Lots of unkown
Show messages:  1-3  …  304-323  324-343  344-363  364-372
15 Nov 2021   [#364] In reply to [#363]
Hi Tudor,
> 1. If I'll move an object, scale, rotate - it will count as last object, not new one created(let's say I've
> created a circle before - and script will record last object as LastCreated)
Yes, this is the intended behavior. When you move, scale, or rotate an object the original object is deleted and a new one is created.
> 2. after creation if i'll cancel next operation, it wount count as last created (ex: created circle, try to move,
> didn't like, cancel - Last created won't count any more, history gone)
Yes this is also how it is intended to work. The "last created" information that you are gathering is what was created by the last command that was run.
If you run a command and then cancel it that was the last run command and it didn't create anything, so asking for what was created by the last run command should return nothing in this situation.
If those are not doing what you need then you'll need some other mechanism to do it, these are working as they are supposed to.
19 Mar 2022   [#365]
in case like this where are 2 frames of curves - can't fillet the corners (orange/green, orange/blue)
defaults - i think that it should work like blend
19 Mar 2022   [#366] In reply to [#365]
Hi Tudor, can you please post the .3dm model file with that geometry in it?
19 Mar 2022   [#367] In reply to [#366]
out of space, expand my inbox )))
https://easyupload.io/6wcc94
orange/greeen - for blend
orange/blue for fillet
19 Mar 2022   [#368] In reply to [#367]
Hi Tudor, thanks for posting the file. I was hoping that would help me understand what you are asking about but I'm afraid that I still don't understand.
Are you trying to fillet curves instead of edges?
Not understanding this either, do you mean you've already done a blend between orange and green and a fillet between orange and blue?
Sorry I'm not getting it, - Michael
20 Mar 2022   [#369] In reply to [#368]
so fillet i consider ~ a corner turn to rounded curvature with a radius
same principle want to be from blue to orange (file I've posted I've cut a part from curve (orange green) for a blend) that i'd consider as a fillet
moi doesn't have any implementation for corner blend radius -> aka fillet
https://easyupload.io/22suev explained in moi
20 Mar 2022   [#370] In reply to [#369]
Hi Tudor, for curve filleting the curve segments to be filleted need to be coplanar.
That's both a limit in the geometry library and also just in general on non-coplanar setups there often won't be a spot where an arc of the given radius exists that is tangent to both curves.
20 Mar 2022   [#371] In reply to [#370]
either in fillet tab (extra option for non-coplanar) or in blend tab with a corner selected (will act like fillet - thats why i'm more towards option in fillet tab) , both doing same thing, cut a distance and make blend together
the way i'm imagining cutting is a sphere growing radius from corner introduced by user, where sphere intersects with lines - make a cut & blend after, if growing sphere(radius) meets 3'd intersection point, algorithm fails
ofc if wont be fillet radius, but calculated radius (technically not part of fillet)
20 Mar 2022   [#372] In reply to [#371]
Hi Tudor, yes the problem is that if you cut something by intersection with a sphere then if you try to put in a circular arc segment between the cut pieces the arc will not be tangent to both cut ends.
