Full Version: Lots of unkown
Show messages:  1-18  …  179-198  199-218  219-238  239-258  259-278  279-298  299-318  …  359-372
27 Aug 2020   [#239] In reply to [#238]
Doing the surface creation and shelling "after" tge flow, allows me to monitor the validity of the solid better. I would expect the loft or shell to fail if i had created a "to tight to bend" situation, where flowing the solid result, could more easily allow me to create some type of "bad" geometry (folding over on itself, etc.)
28 Aug 2020   [#240]
u are moi monsters, perfect results !
thanks !
28 Aug 2020   [#241] In reply to [#238]
@ Michael : why we can't retake the first vertical line as Base Line for the Flow Function ?
You can, but it's a little difficult to select it since it's in the same location as a surface edge and the edge is getting priority.
Use Edit > Hide to hide the surface so you can then click select the first vertical line for the Flow base line.
29 Aug 2020   [#242] In reply to [#241]
Thx for the Info!
I was not enough perceiving! :)
8 Sep 2020   [#243]
ohayo !
Michael how can I add a script page to show last updates of scripts (remove history tabs) or better will be github ?
8 Sep 2020   [#244] In reply to [#243]
Hi Tudor, you could make a post here in the forum and then link to the forum thread. Github is a good idea too though.
29 Sep 2020   [#245]
rectangle interactive
the idea is to combines all rectangles under one shortcut and switch between them from hotkeys
q rect
w rect center
e rect 3pt
r - will be added - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164 -> rect with 3ptcenter ~ another way to grow new rectangles
script is unfinished
rect_interactive.js
30 Sep 2020   [#246] In reply to [#245]
Hi Tudor.
Only one rectangle ;-)
30 Sep 2020   [#247]
looks a like a runtime error, I dont have it !
it's about moi version or smt else not related to the script
or it might ask for html .. that I havent work on, try to add if it works
rect_interactive.htm
30 Sep 2020   [#248] In reply to [#247]
Hi Tudor.
Ok!
13 Oct 2020   [#249]
Ohayo
will be possible to improve antialiasing on plane surfaces ?
13 Oct 2020   [#250] In reply to [#249]
Hi Tudor,
> Ohayo
Not for v4 but possibly at some point down the road.
13 Oct 2020   [#251]
Thnkas !
& I have one more modeling challange ! I was looking around moi todo it
It's a new year toy that has to be twisted ~~~ I gave up doing in moi
13 Oct 2020   [#252] In reply to [#251]
Hi Tudor, maybe try the Transform > Deform > Twist command for that. Something like this:
tudor_twist_toy1.jpg  tudor_twist_toy2.jpg  tudor_twist_toy3.jpg  tudor_twist_toy4.jpg
13 Oct 2020   [#253]
no control over twist, and ~ the countour that i need ~ misses the uv
testo.3dm
Message 8665.254 was deleted
31 Oct 2020   [#255]
any way that fillet g1-g3 could have a second slider for adjusting scaling*?
31 Oct 2020   [#256] In reply to [#255]
Hi Tudor,
There isn't any way to set that up now but I would I would like to give some attention to Blend in the future and that is one of the things that I would like to do. Bring it up again when the v5 beta is underway.
21 Nov 2020   [#257]
discovered smt new today !
if curves are mirrored & attach each other -> they can extrude a solid object without union ! neat !
24 Nov 2020   [#258]
hotkeys
add point
c - close curve
d - delete corners
AddPoint.js
