153-172
173-192
193-212
213-232
233-252
253-272
273-292
Isocurve
v - swap between u/v
b - both
Isocurve.js
Hi Michael
another future that i'd like to see -> u might not accept it
ctrl dragging(dublicate) - assign snap during dragging -> shift is straight, alt -> removes snaps, what about 'space' - readjust snapping point (readjust anchor position)
Hi Tudor, sorry no I don't think that would be very easy to add. If you want a specific anchor position, use the Transform > Move command instead of object dragging.
I'll put this at wish List
habit for select - apply action -> fillet/chamfer control points
the way it works now if points are selected, u can't apply action instead is returning to object selection
Chamfer hotkeys -> works only with 1 distance
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*2
Numpad/ -> value/2
Ctrl+Shift+Numpad+ -> value +value/100
Ctrl+Shift+Numpad- -> value - value/100
r - reset distance to 0 -> to start new one
Chamfer.js
scale/rotate/move gizmo
move - holding shift has a snapping direction, will be nice also for scale snapping direction
found a solution for move -> copy
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
Move
added C -> move copy (duplicate origin with move hotkeys options), works before 1'st picked point
Move.js
Hi Tudor,
Shift is already being use there for a different function, it does a 2D scale instead of a 3D scale.
Hi again !
So a question about pointpicker -> Is any option to force update ?
I've noticed in move commands - where I swap axis by hotkeys & it won’t update until I'll do a mouse move - seems that forces to update factories
now I'm working in combining rectangles under 1 script - needs also a pointpicker update (I'm updating factory - but since pointpicker haven't changed -> no updates) have a basept, need to update second pt or waitable pointpicker pt
Hi Tudor,
Not currently but I have added in a pointpicker.recalc() function for the next beta to do that.
I wonder if it will possible to hide edges between faces with same continuity* ex: fillet
Hi Tudor, can you show an example?
left all in
right - desired
Hi Tudor, there is a new function for edge curves in the next beta: edge.getIsTangentEdge() , it should help for making a script that would hide things like you want.
The way you will be able to use it is like this:
var breps = moi.geometryDatabase.getObjects().getBReps();
for ( var i = 0; i < breps.length; ++i )
var edges = breps[i].getEdges();
for ( var j = 0; j < edges.length; ++j )
if ( edges[j].getIsTangentEdge() )
edges[j].hidden = true;
awesome ! thanks !
Ohayo
I have a modelling question (used sweep to spiral)
needs to be spiral, i've tried different shapes, all awkward
test.3dm
Generally when you use the Sweep function it's a good thing to put 2 rails for control each side of the profil on the Helix...
Hi Tudor, I think you want the "Twist = Flat" option and also use "Set flat direction" along your axis:
The "Twist = Flat" option means the profile will not rotate freely around the rail tangent, it will be limited to only pivot around the "flat direction".
The default "Flat direction" is the world z axis, so when you have some other direction you need to click "Set flat direction" to set it.
Another way you can make this kind of thing is by extruding your profile out straight and then use Transform > Deform > Twist on it.
@PILOU
i need Mike result, the way u are showing come to same issue that I have
@Michael Gibson
I haven't used twist modifier so deeply, can u explain step by step how I can reach such result ?
mb gif animation
153-172
173-192
193-212
213-232
233-252
253-272
273-292
