Full Version: Lots of unkown
Show messages:  1-20  …  141-160  161-180  181-200  201-220  221-240  241-260  261-280  …  361-372
12 Aug 2020   [#201] In reply to [#198]
Hi Tudor,
> for offset - through point, I wanna store value for next op - have the same as previous - how
> shall I do it ? (temporary global save*)
There's moi.command.setOption() and moi.command.getOption() that can be used for that.
The setOption works like: moi.command.setOption( 'string_id', val );
getOption goes like this:
var val = moi.command.getOption( 'string_id' );
One thing to watch out for is that getOption() will throw an exception if there isn't anything saved with that string id before, so you need to use it in a try/catch block like this:
var Val = 5;
try {
Val = moi.command.getOption( 'string_id' );
catch(e) {}
12 Aug 2020   [#202] In reply to [#199]
Hi Tudor,
> magic of offset ~ weird behavior
Offset has been tuned up quite a bit already for the next beta and it shouldn't make the weird excessive extensions anymore.
It will try to make a G2 continuous extension but it looks at how much the extension bends and once it is beyond a limit it switches to G1 line extensions:
12 Aug 2020   [#203]
thanks !
13 Aug 2020   [#204]
rectangle round corner if forgot check button - applies instead of cancel entire op
GetRectRoundCorner.js
13 Aug 2020   [#205]
for offset - here's a solution
if (pointpicker.event == 'finished') {
moi.command.setOption('OffsetCurveDistance', factory.getInput(1));
break;
if I'll need i can swap from thought point, to distance by hotkey or manual .. it will remember last input
offset factory input 1 = distance
but
moi.ui.alert(factory.getInput(1)) returns moi.object. Is a way to return value? or search for another way ?
13 Aug 2020   [#206] In reply to [#205]
Hi Tudor,
factory.getInput(index) returns a geometry factory input object which has a getValue() function on it.
13 Aug 2020   [#207]
sry but I have and error ..
it's making smt & I can't define where's the error
13 Aug 2020   [#208] In reply to [#207]
Hi Tudor, if the input has never been initialized with any value, it will throw an "operation failed" exception.
So you would need something like:
var gotvalue = false;
var value;
try {
value = input.getValue();
gotvalue = true;
} catch(e){}
13 Aug 2020   [#209]
nope
factory.getInput(1) - returns object
factory.getInput(1).getValue() - always undefined
my assumption is that
1. cuz it wasnt any init from js (factory.setValue(1)...) it cant read the values from factory
2. factory.getInput(1) - has a different object format
3. curveOffsetDistance internal is returning undefined after execution -> while dragging offset - the value is always 0
I give up
13 Aug 2020   [#210] In reply to [#209]
Hi Tudor, if you can post a complete script file that I can run over here I can take a look.
14 Aug 2020   [#211]
vanilla offset with hotkeys modifications
d -> swap from thought point to distance -> idea is to keep through point to distance value, so on next offset will remember last action -> since distance has already a build-in setOption
Offset.js
14 Aug 2020   [#212] In reply to [#211]
Hi Tudor, for offset the input index 1 is for a distance value, it is only filled in if you are using offset in its "offset by specific distance" mode, not in through point mode.
So for example if you type in 3 and push enter that input will get initialized to 3 and then your messages would show "3" and "true" when you pick a point for which side to offset on.
There was at one point a "curveOffsetDistance" additional property on the offset factory that would give back the current distance used for "through point" mode, but it's not working currently. I'll take a look and see if I can get that working.
14 Aug 2020   [#213]
Isocurve
v - swap between u/v
b - both
Isocurve.js
15 Aug 2020   [#214]
Hi Michael
another future that i'd like to see -> u might not accept it
ctrl dragging(dublicate) - assign snap during dragging -> shift is straight, alt -> removes snaps, what about 'space' - readjust snapping point (readjust anchor position)
15 Aug 2020   [#215] In reply to [#214]
Hi Tudor, sorry no I don't think that would be very easy to add. If you want a specific anchor position, use the Transform > Move command instead of object dragging.
16 Aug 2020   [#216]
I'll put this at wish List
habit for select - apply action -> fillet/chamfer control points
the way it works now if points are selected, u can't apply action instead is returning to object selection
16 Aug 2020   [#217]
Chamfer hotkeys -> works only with 1 distance
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*2
Numpad/ -> value/2
Ctrl+Shift+Numpad+ -> value +value/100
Ctrl+Shift+Numpad- -> value - value/100
r - reset distance to 0 -> to start new one
Chamfer.js
16 Aug 2020   [#218]
scale/rotate/move gizmo
move - holding shift has a snapping direction, will be nice also for scale snapping direction
16 Aug 2020   [#219]
found a solution for move -> copy
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
Move
added C -> move copy (duplicate origin with move hotkeys options), works before 1'st picked point
Move.js
16 Aug 2020   [#220] In reply to [#218]
Hi Tudor,
Shift is already being use there for a different function, it does a 2D scale instead of a 3D scale.
