Hi Cemortan, some commands like Loft keep track of whether the curves used for building the surface needed to be flipped or have their "seam" start/end point (for closed curves) to be modified from the curve's own natural direction and seam point in order to avoid making a twisted surface. This information is stored in a factory input so that if the curves are edited and a history recalculation is done it will use the same orientations and seam points from the original loft (which may be customized by the user by clicking on a closed curve or dragging a point) rather than trying to make new ones.
Usually this is done automatically by the loft factory but the function you are asking about will build the orientation list manually, the list will have one CurveOrientation object per curve passed in, the curve orientation object (IMoiCurveOrientation in the moi.idl file) has "flipped" and "seam" properties on it.
I've made a script that extends tangecy by 2 units (for those who are using pipe, to extend current line by some extra units)
I'm bad at moi html and a binding ui will be later updated !
another script, same as in zbrush
quick snap 3d view to side/top/bottom other angles, if co-working with Iso view - perfect tool for 4 cutting
i'd wish this script in main moi!
there's a glitch .. while i was testing it so often, setting up upDownAngle, leftRightAngle, tiltAngle i still can see 1 extra frame of script execution... here Michael if will have time could help
Hi Cemortan, I think there's a bug somewhere in setting tilt angles where you may need to set it twice in a row to get it to the full position, you might try setting it twice in your script and see if that helps for now.
nope, didn't work
as much i don't feel that my computer is slow & it's not handling operations ! as far as i notice JS is doing on the fly, can't control timer or delay of execution.
not too important afterwall
Michael Hi !
It was mentioned before about loop, why not to grab from SpaceClaim the loop
alla(https://youtu.be/-oJ5Xypordo?t=1m47s)
if 1 edge is selected {
check if it's line/curve type ! check for closest surfaces
__if line
_____pick a point from edge of adjustment surface, make a frame from it with first 2 points, check the surface points if are alligned to the frame -> make selection
__if curves
_____can be 1'st, end point and any arbitrary from curve point -> frame & again checks -> make selection
// bassicly we are are checking if adjustment surfaces are flat, if not break )) manual selection!
if 2 edges are selected - run the scrit that u've done !
They are Limitations JS and this can be done only in CORE(i'll write about those later)
thanks !
I consider them as BUGS !
1. do the same in moi https://youtu.be/-QDjJ67b3kA?t=2m35s
2. can make a video if it's needed
draw a rectangle, show points ON
click on a curve and start dragging
my intention is to change the hight/skew of rectangle, instead i obtain weird solutions :)
Hi Cemortan, if you have points turned on and you drag on the main curve when it is not selected, it will use a drag mode used for adjusting control points to make the curve move through the point you are dragging, like this:
That method adjusts several control points in one action.
If you want to move the entire curve instead of adjusting control points while still having points on, you can do that by selecting the entire curve before dragging it, like this:
@You "...if you have points turned on and you drag on the main curve when it is not selected, it will use a drag mode used for adjusting control points to make the curve move through the point you are dragging"
"IntelliSense is a general term for a variety of code editing features including: code completion, parameter info, quick info, and member lists. IntelliSense features are sometimes called by other names such as "code completion", "content assist", and "code hinting."."
So if such files were added to the coding/text editors/environments, Visual Studio, or Sublime, they would assist with writing MoI scripts?
yes, therefore where designed those scripts
VsCode extension TypeSearch
Sublime extension All Autocomplete
On http://moi.maxsm.net/api/ are not all the functionality provided by moi.idl & it's much easier to read JS scripts than IDL's
moi.js
. abstract variables are just for defining
. autocomplete - yes, both !
. JsDoc supported only by VsCode, haven't search deeper for sublime
geometryFactory.js -> created object to view factory inputs, screenshots are self explanatory
