Full Version: Lots of unkown
Show messages:  1-3  …  124-143  144-163  164-183  184-203  204-223  224-243  244-263  …  364-372
18 Jul 2020   [#184] In reply to [#183]
Hi Tudor,
> crv.evaluateCurvature - how can I access first and second pt of vector ? -> tried -> [], item(), getStartPt()
There is not a first and second point returned, it returns one vector value (with .x, .y, .z - same as a point) for the curvature vector (K) of the curve in the osculating plane at that parameter value. Radius of curvature = 1 / Magnitude K.
https://en.wikipedia.org/wiki/Curvature#Osculating_circle
19 Jul 2020   [#185] In reply to [#183]
re: crv.evaluateCurvature, here is some test code. Make a curve, select it and then push the Tab key and paste this in to the XYZ input control:
var crv = moi.geometryDatabase.getSelectedObjects().getCurves().item(0);
var pt = crv.evaluatePoint( crv.domainMin );
var K = crv.evaluateCurvature( crv.domainMin );
var f = moi.command.createFactory( 'line' );
f.setInput( 0, pt );
f.setInput( 1, moi.vectorMath.add( pt, K ) );
f.commit();
That will make a line showing the curvature vector. The radius of curvature is 1 / length of that line.
Curvature vectors are generally scaled up by quite a bit when used for visualization purposes. They tend to be small in their direct form.
19 Jul 2020   [#186]
thanks ! that's what i've needed !
21 Jul 2020   [#187]
how can I get toplevel from a selection (ex:face or edge to object)
21 Jul 2020   [#188] In reply to [#187]
Hi Tudor,
var toplevel = subobj.getTopLevelParent();
23 Jul 2020   [#189]
Hi Michael !
is it possible to attach moi-html to chrome to have futures like object explorer/building html ?
or other ways to debug
23 Jul 2020   [#190] In reply to [#189]
Hi Tudor,
> Hi Michael !
No, not currently. In the future I want to have a script debugger in MoI, it will involve a lot of work to make that happen though.
Message 8665.191 was deleted
1 Aug 2020   [#192]
Hi Michael !
I think this should rise an error
createPoint(moi.vectorMath.add(obj.getStartPt(), scaleVector(obj.evaluateTangent(obj.domainMin), -1))).commit() - correct state
createPoint(moi.vectorMath.add(obj.getStartPt(), scaleVector(obj.evaluateTangent(obj.domainMin)),-1)).commit() - should rise -> it creates an null point
function scaleVector(v, factor) ... return moi.vectorMath.createPoint(x,y,z)
9 Aug 2020   [#193]
Hi Michael !
I'm working a script & I wanna optimize it ! it uses a lot of moi.vectorMath.add()
wanna ask what's the math behind that function ? mb will improve runtime (not to call internals todo math operations )
9 Aug 2020   [#194] In reply to [#193]
Hi Tudor,
Like this:
var PtA, PtB, Result;
Result.x = PtA.x + PtB.x;
Result.y = PtA.y + PtB.y;
Result.z = PtA.z + PtB.z;
10 Aug 2020   [#195]
scripts for edge selection :
I wanted ~ growLoop similar to Subd, with v4 it became possible
works only for 1 selected object -> possible multiple edge selection
_GrowSelectionTangecy - expands only once
_ExpandSelectionTangecy - expands full selection
testing files are on moi_objects.rar
I haven't done more optimization since ~ 140ms is good result on big_object test (started from 20s -> 2s -> 1.2s-> 0.140)
quick Notes:
factory.Update() + getCreatedObjects() - it's slow process - better avoid it
looping same object - debugging -> might have different selection order - idk why it's happening - have to place into java object
Ps: why getEndPt() != domainMax ?
moi_objects.rar
_ExpandSelectionTangecy.js
_GrowSelectionTangecy.js
10 Aug 2020   [#196]
add point
D -> delete corners
AddPoint.js
10 Aug 2020   [#197]
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.136
Shortcuts for manipulation:
Fillet; Inset; Shell ; Offset(Brep)
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*2
Numpad/ -> value/2
//added
small adjustments
Ctrl+Shift+Numpad+ -> value +value/100
Ctrl+Shift+Numpad- -> value - value/100
r - reset distance to 0 -> to start new one
GetDistance.js
12 Aug 2020   [#198]
Hi Michael
for offset - through point, I wanna store value for next op - have the same as previous - how shall I do it ? (temporary global save*)
12 Aug 2020   [#199]
magic of offset ~ weird behavior
buggy_offset.3dm
12 Aug 2020   [#200]
I've tested in other software to see if it's rly a problem !
Rhino Fails - buggy
DesignSpark Mechanical - buggy
Illustrator - it doest care about continuity
Fusion 360 - it maxed the continuity- when it breaks, will round corners
12 Aug 2020   [#201] In reply to [#198]
Hi Tudor,
There's moi.command.setOption() and moi.command.getOption() that can be used for that.
The setOption works like: moi.command.setOption( 'string_id', val );
getOption goes like this:
var val = moi.command.getOption( 'string_id' );
One thing to watch out for is that getOption() will throw an exception if there isn't anything saved with that string id before, so you need to use it in a try/catch block like this:
var Val = 5;
try {
Val = moi.command.getOption( 'string_id' );
catch(e) {}
12 Aug 2020   [#202] In reply to [#199]
Hi Tudor,
Offset has been tuned up quite a bit already for the next beta and it shouldn't make the weird excessive extensions anymore.
It will try to make a G2 continuous extension but it looks at how much the extension bends and once it is beyond a limit it switches to G1 line extensions:
12 Aug 2020   [#203]
thanks !
