Full Version: Lots of unkown
Show messages:  1-19  …  120-139  140-159  160-179  180-199  200-219  220-239  240-259  …  360-372
18 Jul 2020   [#180] In reply to [#179]
It's true that i'm trying to achieve common environment for modeling - hard surface - will be neat future for history sweep update (shape creation)
Here comes a question - I know disable update - will disable sweep's update(idk others which can update) but manual update on what it works ? -> enable history ?
pointpicker.bindFunc() & pointpicker.bindFuncPostUpdate() - differences, references, other wiki locations !
Also with last v4 version will be possible to achieve this future - https://github.com/heimlich1024/OD_CopyPasteExternal
copy/paste obj extension between softwares !
by moi.filesystem.getDirs() as all files are in %system%\Windows\Temp folder
//on git Author use version of Smirmov's import obj future that has ~ normalize and ~ move actions (need digging to understand what they are for, if u know the answer !) - as script -> It should copy/replace same object on same position in different softwares !
18 Jul 2020   [#181] In reply to [#180]
Hi Tudor,
It can be enabled on the results from any command except the Array commands which do not emit history records on objects because it can increase file size on larger arrays by quite a bit. The main limitation to the history function though is that it needs to be able to find the input objects in the current geometry database for it to use them for a recalculation. If the original objects have been removed that will break history updates.
bindFunc() will make the pointpicker call to the given function before it updates factory inputs and the function can provide the current point value on the pointpicker that will then get pushed to the factory inputs. bindFuncPostUpdate() will make the pointpicker call to the given function after the update sequence has happened so it can look at the results of the update.
I think that system is already working with MoI v3 and v4.
I think that Max noticed that some programs make .obj files that happen to be at what is considered an unusually small or large scale in MoI, and so he implemented a method to rescale objects to a more normal size when they are read in which is enabled by default. But that is not good for keeping unit sizes the same and so there is an "exact" command line parameter that you can pass in to the script to turn that off:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.453
18 Jul 2020   [#182]
move - expanded first actions - move + x/y/z/a initial conditions (earlier script respond after first pickedpoint)
s - bbox center
extrude - do backup as part is havelly changed from vanilla
p path
b both directions
c cap ends
d directional // changed - removed distance line and input distance (slightly buggy on surfaces if keypressed while moving mouse - I think it can't update in time and skips update factory)
f tapered/flip tapered
Numpad+ increase tapered angle by 15
Shift+Numpad+ increase tapered angle by 5
Numpad- decrease tapered angle by 15
Shift+Numpad- decrease tapered angle by 5
removed t as hotkey
boolean difference
for closed curves
initial and subtractive if both are on same parallel frame but different frame
move subtractive group to initial and do the boolean difference (made for side views where u see that u have 2 circle's but u cannot subtract cuz they have different frames)
BooleanDifference.js
Extrude.js
Move.js
18 Jul 2020   [#183]
crv.evaluateCurvature - how can I access first and second pt of vector ? -> tried -> [], item(), getStartPt()
18 Jul 2020   [#184] In reply to [#183]
Hi Tudor,
There is not a first and second point returned, it returns one vector value (with .x, .y, .z - same as a point) for the curvature vector (K) of the curve in the osculating plane at that parameter value. Radius of curvature = 1 / Magnitude K.
https://en.wikipedia.org/wiki/Curvature#Osculating_circle
19 Jul 2020   [#185] In reply to [#183]
re: crv.evaluateCurvature, here is some test code. Make a curve, select it and then push the Tab key and paste this in to the XYZ input control:
var crv = moi.geometryDatabase.getSelectedObjects().getCurves().item(0);
var pt = crv.evaluatePoint( crv.domainMin );
var K = crv.evaluateCurvature( crv.domainMin );
var f = moi.command.createFactory( 'line' );
f.setInput( 0, pt );
f.setInput( 1, moi.vectorMath.add( pt, K ) );
f.commit();
That will make a line showing the curvature vector. The radius of curvature is 1 / length of that line.
Curvature vectors are generally scaled up by quite a bit when used for visualization purposes. They tend to be small in their direct form.
19 Jul 2020   [#186]
thanks ! that's what i've needed !
21 Jul 2020   [#187]
how can I get toplevel from a selection (ex:face or edge to object)
21 Jul 2020   [#188] In reply to [#187]
Hi Tudor,
var toplevel = subobj.getTopLevelParent();
23 Jul 2020   [#189]
Hi Michael !
is it possible to attach moi-html to chrome to have futures like object explorer/building html ?
or other ways to debug
23 Jul 2020   [#190] In reply to [#189]
Hi Tudor,
> Hi Michael !
No, not currently. In the future I want to have a script debugger in MoI, it will involve a lot of work to make that happen though.
Message 8665.191 was deleted
1 Aug 2020   [#192]
Hi Michael !
I think this should rise an error
createPoint(moi.vectorMath.add(obj.getStartPt(), scaleVector(obj.evaluateTangent(obj.domainMin), -1))).commit() - correct state
createPoint(moi.vectorMath.add(obj.getStartPt(), scaleVector(obj.evaluateTangent(obj.domainMin)),-1)).commit() - should rise -> it creates an null point
function scaleVector(v, factor) ... return moi.vectorMath.createPoint(x,y,z)
9 Aug 2020   [#193]
Hi Michael !
I'm working a script & I wanna optimize it ! it uses a lot of moi.vectorMath.add()
wanna ask what's the math behind that function ? mb will improve runtime (not to call internals todo math operations )
9 Aug 2020   [#194] In reply to [#193]
Hi Tudor,
Like this:
var PtA, PtB, Result;
Result.x = PtA.x + PtB.x;
Result.y = PtA.y + PtB.y;
Result.z = PtA.z + PtB.z;
10 Aug 2020   [#195]
scripts for edge selection :
I wanted ~ growLoop similar to Subd, with v4 it became possible
works only for 1 selected object -> possible multiple edge selection
_GrowSelectionTangecy - expands only once
_ExpandSelectionTangecy - expands full selection
testing files are on moi_objects.rar
I haven't done more optimization since ~ 140ms is good result on big_object test (started from 20s -> 2s -> 1.2s-> 0.140)
quick Notes:
factory.Update() + getCreatedObjects() - it's slow process - better avoid it
looping same object - debugging -> might have different selection order - idk why it's happening - have to place into java object
Ps: why getEndPt() != domainMax ?
moi_objects.rar
_ExpandSelectionTangecy.js
_GrowSelectionTangecy.js
10 Aug 2020   [#196]
add point
D -> delete corners
AddPoint.js
10 Aug 2020   [#197]
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.136
Shortcuts for manipulation:
Fillet; Inset; Shell ; Offset(Brep)
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*2
Numpad/ -> value/2
//added
small adjustments
Ctrl+Shift+Numpad+ -> value +value/100
Ctrl+Shift+Numpad- -> value - value/100
r - reset distance to 0 -> to start new one
GetDistance.js
12 Aug 2020   [#198]
Hi Michael
for offset - through point, I wanna store value for next op - have the same as previous - how shall I do it ? (temporary global save*)
12 Aug 2020   [#199]
magic of offset ~ weird behavior
buggy_offset.3dm
