Full Version: Lots of unkown
Show messages:  1-17  …  98-117  118-137  138-157  158-177  178-197  198-217  218-237  …  358-372
8 Jul 2020   [#158]
Thanks ! next time I'll ask if it's working xD
I thought it will work in different way
_extendTangency 1.1
* added htlm
add functions + hotkeys
b - bothsides
a - join
f - flip sides (here I've needed ~ restrict line direction - not Togo opposite tangency direction)
script is not ended, but it has a good chunk of it, will return when i'll know more about html and moi basefunctions
_extendTangecy.htm
_extendTangecy.js
8 Jul 2020   [#159]
how can i get difference between parallel frames ?
8 Jul 2020   [#160] In reply to [#159]
Hi Tudor,
Do you mean the difference in the origin points between 2 coordinate frames?
That would be like this:
var dx = FrameB.origin.x - FrameA.origin.x;
var dy = FrameB.origin.y - FrameA.origin.y;
var dz = FrameB.origin.z - FrameA.origin.z;
8 Jul 2020   [#161]
between parallels - similar to distance of projection of 1 pt from 1 frame to another
9 Jul 2020   [#162] In reply to [#161]
Hi Tudor, sorry it's not clear to me what you're trying to do.
If it's something like transforming the coordinates of a point in global x,y,z coordinates into coordinates relative to a frame, that would be like this:
var local_x = frame.distancex( pt );
var local_y = frame.distancey( pt );
var local_z = frame.distancez( pt );
The .distancex, .distancey, and .distancez functions on a coordinate frame return the distance of a point in world coordinates along the x, y, or z axis direction planes of the frame.
If that's not it then I need a clearer description of what you're trying to do, it's hard to figure out what you're asking about if you don't provide some more details.
9 Jul 2020   [#163]
bool operations of standalone curves that have different frames but are parallel to each other (ex circle at 0 0 0 and another at 1 1 1) -> to apply a move to second group(for difference will be subtract objectgroup) & do the bool
9 Jul 2020   [#164]
rect3pts with center
RectCenter3pt.htm
RectCenter3pt.js
9 Jul 2020   [#165] In reply to [#163]
Hi Tudor,
Is this something that you're trying to script? Can you show an example of the input objects and the result you are trying to make?
9 Jul 2020   [#166]
scene browser - objects are named
there is a solution - to create laaaaarge plane - and second group of objects to drop a point on this plane(project), and apply a move
mb is another solution
bool_scene.3dm
9 Jul 2020   [#167]
another script that i'm trying to work on is trim a segment or cut a segment from a curve
the problem that i'm conflicting is that i have todo a separate object - commit and later choose from sepFactory
I dont know what objects are created after commiting, or how can I set a variable to them ! sepFactory.commit().lenght = 0
what's happening after a commit ?
9 Jul 2020   [#168] In reply to [#166]
Hi Tudor,
> plane(project), and apply a move mb is another solution
Ok, if you have a solution what do you need? Is there a question you have about this?
9 Jul 2020   [#169] In reply to [#167]
Hi Tudor,
A .commit() is expected to be the last thing that is called on a factory, it is a signal to MoI that the work being done for the factory with updating different inputs is all finished.
If you want to get the objects that will be generated, you can instead call .update() and then .getCreatedObjects(). Or it is also possible to call .calculate() which will generate the result and return it as an object list without adding it in to the geometry database like usually happens in regular commands with .update()/.commit()/.cancel() .
9 Jul 2020   [#170]
All these Scripts (?) are they on a same place ? (Sites...)
9 Jul 2020   [#171]
thanks ! found also older posts by u'r recommendations
Trim hotkeys
t - trim add point
s - trim single segment (~ if u click wrong object it will delete that object -> there are no restriction to object selection)
Trim.js
9 Jul 2020   [#172] In reply to [#170]
single person trying to understand moi in depth - yes
mb later will open a git for scripts
don't like multiple theme option
9 Jul 2020   [#173] In reply to [#172]
Thanks for the infos!
Message 8665.174 was deleted
10 Jul 2020   [#175]
i'm messing with bool operations difference operations to see all the states for curves
so ~ there's a glitch
on a shape like this with keep objects will delete 'baseobjects'
bool_tests1.3dm
10 Jul 2020   [#176] In reply to [#175]
Hi Tudor, yes the curve booleans can get confused if you do a boolean between an open curve and a closed curve like that.
You can do an open curves as the base object and a closed curve as the cutter but a closed curve as the base object and an open curve as the cutter will tend to make some weird results. I would recommend to avoid using that combination.
Message 8665.177 was deleted
