70-89
90-109
110-129
130-149
150-169
170-189
190-209
370-372
is that if clicked?
anything without clicking ? cuz if I click something, scripts ends it's action
otherworlds I need current pointposition without click
if (!wasAnyHotkey) {
moi.command.setOption( 'AlignMode', 'VerticalLeft' );
factory.setInput( 2, 'VerticalLeft' );
factory.update();
wasAnyHotkey = true;
else {
//here i need help !
pointpicker.pt = pointpicker.ptframe.origin ;
factory.commit();
DoAlign();
Hi Tudor,
> is that if clicked?
No, it's available anytime the pointpicker has been able to get a point, like with mousemove.
Yes, that's how the regular Align command is supposed to work. When you click a point a 'finished' event will be triggered, and this part of the script exits the even loop when it sees that;
while ( 1 )
if ( !pointpicker.waitForEvent() )
return;
>>> if ( pointpicker.event == 'finished' )
>>> break;
If you don't want the script to end when a point is clicked you would want to modify what it does with the 'finished' event, like ignore it.
Thanks Michael
Align Hotkeys
w - top
s - bottom
a - left
d - right
q - Vertical Center
e - Horizontal Center
added
align corners
ex: w+a/w+d/s+a/s+d
underTest_Align.js
based on
https://github.com/arekm/rsdoc-to-sat
Convert DesignSpark Mechanical DSM rsdoc file to sat file which can be loaded into MoI3d
Installation -> python3
drag & drop rsdoc file(s) onto rsdoc-to-sat.py file
.sat file(s) will appear in the same directory as rsdoc file(s).
author went via winreg path, i've changed path inside script to full path ~
inside script change path of sabsat to full path of SabSatConverter.exe (it comes with full DSM installation)
sabsat = "C:\\Program Files\\DesignSpark\\DesignSpark Mechanical 4.0\\SabSatConverter.exe"
rsdoc-to-sat.py
o hayo !
v4 new future crv.evaluateCurvature
I'm thinking about script for edge loop up to ~ broken curvature on a brep (on curve will be a sharp corner)
if i'm extracting curves, how shall i transfer back to edges ?
Hi Tudor,
Sorry I'm not sure I understand this - you can call curve evaluate methods on an edge curve just like you can on a "standalone" curve.
One thing to be aware of is that a curvature break between 2 edge curves does not mean anything about the continuity of the surface at that point. For example:
Shortcuts for manipulation:
Fillet; Inset; Shell ; Offset(Brep)
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*value
Numpad/ -> value/value
GetDistance.js
http://moi3d.com/wiki/V4Beta
Scripting:
Added additional script interface for Curve and CurveSegment objects.
For both Curves and CurveSegments:
wasn't any mention about edges, will try !
About align - 3d viewport -> I think it should be aligned along camera position - not along axis
Hi Tudor,
Edge curves and "standalone" curves have the same curve interface object.
Can you show an example of what you mean?
Unified under one command Union and Join ~ they do they same, need more testing
UnionJoin.htm
UnionJoin.js
based on camera angle what's left/right/top/bottom
Hi Tudor, that's an interesting idea. But what if your camera angle is right near a switchover spot? That would probably mean that you could get in a situation where you move the camera a slight amount and get a big shift in the result.
yes, but at the current align i have to guess what button should i press
for static i could change to orto views !
Hi Tudor, you don't have to guess if you look at the x/y/z axis tripod display in the lower left corner:
dont have them xD well, it was a suggestion(intuitively will be right and left - ! all we know what it means xD no x & y's - it was written right side ! why it haves weird xD ))
I'm in another propose script ~ isolate update
now - the way it works it now it isolates objects, next call unhides all
what i want - isolate to update on selected objects(ex: doing some operation on objects, isolate to work further), on deselect - call isolate - unhide all. for that i need a global variable ! as I've read scripts all variables are inside scripts (i'm still learning js)
benefits - hitting twice isolate to work further - not to much ~ clicking saving
options vanilla - save current color style as default
I respect blender for community they've grow
cplane as internal doesn't have options locating hotkeys reset, etc
I like pointpicker.addSnapPoint( startpt, moi.ui.getText('Closed snap') ); -> moi.ui.getText()
can it be fixed at a viewport camera position (aka : bottom right; wanna do mini helper for added hotkeys that i'm doing ~
https://youtu.be/8k2NGWrKbj4?t=1239 bottom right ) only when moved over show helper (new lines will be welcome) : personalized -> mb yes -> if u won't see growth in this direction ! (I know that u want viewport as clean as possible, asking for ~ a helper point/style without can be improved - need agreement )
this also can be applied to filters ( which I have to have opened browser to view which one is active - aka edg/faces/solids/so on)
Hi Tudor,
No, that's not how it works now. The way it works now is on the first call it saves a snapshot of the hide/show state of all objects to internal memory, then it does an isolate. The next time you trigger it, it restores things to the pre-isolate snapshot.
For example starting with 6 objects, these 4 are hidden:
Select this object:
Do Isolate, now it is the only one visible and the other 5 are hidden:
Do Isolate a second time, only the object that was visible when the first Isolate was done is visible, not the other 4 objects which remain hidden:
Hi Tudor,
You can do that in MoI by saving a .3dm file with the colors set how you want, then set it as the startup template file under Options > General > Template file, the styles in that file will be used as your default ones when you start up MoI or when you do a File > New :
70-89
90-109
110-129
130-149
150-169
170-189
190-209
370-372
