63-82
83-102
103-122
123-142
143-162
163-182
183-202
363-372
DisableOnSrfInOrtho
Hi Tudor, the runtime script property for that one is moi.drawingAids.disableOnSrfInOrtho
Thanks !
script: /* SurfaceInOrtho */ moi.drawingAids.disableOnSrfInOrtho = !moi.drawingAids.disableOnSrfInOrtho
Message 8665.126 was deleted
Align Hotkeys
w - top
s - bottom
a - left
d - right
q - Vertical Center
e - Horizontal Center
Align.js
wanna improve the align script !
my question is how do i get pointpicker.basept(or value of pointpicker after alignment without clicking) when I'm pressing second hotkey ( let's say I've aligned top, now I need right side -> not to run script twice )
Hi Tudor, the current point for the pointpicker can be accessed using the .pt property on it.
There is also a .cplane property for getting the construction plane (the grid plane) for the pick, and also .ptframe for getting a coordinate frame with its origin at the current point and the frame's axes in the cplane directions.
is that if clicked?
anything without clicking ? cuz if I click something, scripts ends it's action
otherworlds I need current pointposition without click
if (!wasAnyHotkey) {
moi.command.setOption( 'AlignMode', 'VerticalLeft' );
factory.setInput( 2, 'VerticalLeft' );
factory.update();
wasAnyHotkey = true;
else {
//here i need help !
pointpicker.pt = pointpicker.ptframe.origin ;
factory.commit();
DoAlign();
Hi Tudor,
> is that if clicked?
No, it's available anytime the pointpicker has been able to get a point, like with mousemove.
Yes, that's how the regular Align command is supposed to work. When you click a point a 'finished' event will be triggered, and this part of the script exits the even loop when it sees that;
while ( 1 )
if ( !pointpicker.waitForEvent() )
return;
>>> if ( pointpicker.event == 'finished' )
>>> break;
If you don't want the script to end when a point is clicked you would want to modify what it does with the 'finished' event, like ignore it.
Thanks Michael
Align Hotkeys
w - top
s - bottom
a - left
d - right
q - Vertical Center
added
align corners
ex: w+a/w+d/s+a/s+d
underTest_Align.js
based on
https://github.com/arekm/rsdoc-to-sat
Convert DesignSpark Mechanical DSM rsdoc file to sat file which can be loaded into MoI3d
Installation -> python3
drag & drop rsdoc file(s) onto rsdoc-to-sat.py file
.sat file(s) will appear in the same directory as rsdoc file(s).
author went via winreg path, i've changed path inside script to full path ~
inside script change path of sabsat to full path of SabSatConverter.exe (it comes with full DSM installation)
sabsat = "C:\\Program Files\\DesignSpark\\DesignSpark Mechanical 4.0\\SabSatConverter.exe"
rsdoc-to-sat.py
o hayo !
v4 new future crv.evaluateCurvature
I'm thinking about script for edge loop up to ~ broken curvature on a brep (on curve will be a sharp corner)
if i'm extracting curves, how shall i transfer back to edges ?
Hi Tudor,
Sorry I'm not sure I understand this - you can call curve evaluate methods on an edge curve just like you can on a "standalone" curve.
One thing to be aware of is that a curvature break between 2 edge curves does not mean anything about the continuity of the surface at that point. For example:
Shortcuts for manipulation:
Fillet; Inset; Shell ; Offset(Brep)
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*value
Numpad/ -> value/value
GetDistance.js
http://moi3d.com/wiki/V4Beta
Scripting:
Added additional script interface for Curve and CurveSegment objects.
For both Curves and CurveSegments:
wasn't any mention about edges, will try !
About align - 3d viewport -> I think it should be aligned along camera position - not along axis
Hi Tudor,
Edge curves and "standalone" curves have the same curve interface object.
Can you show an example of what you mean?
Unified under one command Union and Join ~ they do they same, need more testing
UnionJoin.htm
UnionJoin.js
based on camera angle what's left/right/top/bottom
Hi Tudor, that's an interesting idea. But what if your camera angle is right near a switchover spot? That would probably mean that you could get in a situation where you move the camera a slight amount and get a big shift in the result.
63-82
83-102
103-122
123-142
143-162
163-182
183-202
363-372
