Full Version: Moi + Affinity : Moi for 2D workflows
Show messages:  1-18  19-38  39-58  59-78  79-90
14 Aug 2024   [#79]
Thanks for the video Danperk - looks good.
I’m wondering if one could bypass the dialogue box
with a script/ shortcut that has the same pdf export settings shown in the video…
14 Aug 2024   [#80] In reply to [#79]
@stefano,
Yes you can pass in some options to use specific settings and not show the dialog, check out here look under "Scriptable options for PDF/AI export."
http://moi3d.com/forum/index.php?webtag=MOI&msg=6579.1
EDIT: fixed wrong link
14 Aug 2024   [#81] In reply to [#77]
Thx for the info! (Michael & Danperk)
Advantage of the "Native" export(s) is that you can have a library of "PDF" files ready to drag & dropped" to Affinity! ;)
You have an Free Online "Illustrator;" https://www.vectorpea.com
tones of exports (not yet found if CTRL +C Crtl +V is working to MOi! :)
but of course normal export PDF or SVG are working! (curioussly not Ai for Moi)
14 Aug 2024   [#82]
Does exist an ClipBoard Import Ai format script to Moi ? Or It's implicit ?
14 Aug 2024   [#83] In reply to [#82]
@Pilou,
It's implicit - if the system clipboard has data in PDF, SVG, or AI3 formats that can be pasted into MoI using the regular Ctrl+V or Edit > Paste commands.
The reason why the other direction is separated out is because it shows a dialog box.
14 Aug 2024   [#84] In reply to [#82]
-"Does exist an ClipBoard Import Ai format script to Moi ? Or It's implicit ? "-
It works with Copy/Paste from Adobe Illustrator, but not sure about other vector programs.
14 Aug 2024   [#85] In reply to [#80]
-"Yes you can pass in some options to use specific settings and not show the dialog, check out here look under "Scriptable options for PDF/AI export."-
I couldn't see that information in the link you posted, I'm getting old, it could be me.
14 Aug 2024   [#86] In reply to [#85]
@danperk - Oops I put the wrong link there, try "Scriptable options for PDF/AI export" here:
14 Aug 2024   [#87] In reply to [#86]
Got it, Thanks!
14 Aug 2024   [#88]
the file Ai from Vectorpea not reloadable by Moi or Affinity 1 (a simple rectangle)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/nouveau_projet.ai
14 Aug 2024   [#89] In reply to [#88]
Looks like it's a newer style AI file that is actually a PDF file, not an AIv8 type file that MoI supports.
You can rename it to nouveau_projet.pdf and open it in Adobe Reader but it appears to be an empty page.
14 Aug 2024   [#90] In reply to [#89]
yep must be recent version ...in any case reloadable by Vectorpea... for other formats if necessary! :)
